crank shaft thread damage
You can try to buy a 16mm x 2.0 tap and clean the threads but there is a very good chance the threads are damaged beyond retapping.
A regular tap will probably work as it's tapered and should find it's way into the original threads.
Go slow, back it out often and use plenty of oil.
Attachment 453646
FYI for the future get your self one of these next time you pull the pulley...
https://www.google.com/search?q=otc+...w&ved=0CBkQsxg
https://www.google.com/search?hl=en&...43.rjdrhNDq1Zc
Grainger Supply lists exactly what you're looking for, $33. Go to their web site and do a location search. There should be a few outlets in your area. Call around until you find one in stock.
Ok thank you very much paul and bob. I just found A grainger 7 miles from me. Going there in a little while.
