How bad is this?
Old May 30, 2014 | 07:26 PM
96blkformula's Avatar
Default How bad is this?
Did a cam swap,started it with the timing off. Took off the heads to find this..
Old May 30, 2014 | 07:34 PM
jrpimp00's Avatar
id be more worried about the valves and pushrods. You can sand down the high spots on the pistons
Old May 30, 2014 | 07:43 PM
Darkman's Avatar
Fly cutting the made easy.
Old May 30, 2014 | 08:42 PM
Going to change the 8 exhaust valves, no rods bent. What else should I worry about?
Old May 30, 2014 | 08:49 PM
Darkman's Avatar
Lifters (at the rollers), and cam lobes if indicated.
Old May 31, 2014 | 04:21 PM
how would you go about sanding these down? dremel tool or sand paper??
Old May 31, 2014 | 08:02 PM
garygnu's Avatar
clean the piston tops off 1st with solvent .then use sand paper and a vacuum source ,to remove any sharp ridges on top of the pistons .what cam did you install ? and how ?
Old Jun 1, 2014 | 12:59 AM
Majestic9C1's Avatar
Just curious why you decided to start it with the timing being off?
Old Jun 2, 2014 | 05:27 PM
transam69230's Avatar
Installation error, **** happens. We were up late , spent all weekend on it. We didnt install rockers and turn the.motor over by hand. Lesson learned.
Old Jun 2, 2014 | 06:03 PM
parks450's Avatar
Dumb mistake, but I'd be a liar if I said I've never done stupid ****. It happens haha, I'd say sand the pistons down with paper, do a check on valves and push rods and put it back together. Maybe time It first this time haha
Old Jun 2, 2014 | 08:17 PM
Dont plan on timing it with a light, it isn't a SBC. Will install heads roll the motor over and go with it.
