What do i do to 241 heads for more power?
Just picked up these 241 heads from a buddy! I want to put some work into these heads before i put em on to make em at least worth the head swap, what can i do to the heads i was told port n polish, but where can i send them off to? And Martin@tickperformance told me i could mill my heads to bring up the compression, but what can i mill them to? Right now I have a rebuilt 98 LS1 with a sns stage 2 cam, ls1 intake, lt headers,ls7 lifters,7.400 pushrods and cold air intake. It is on a 91,C1500 with a 5 speed and 4.10s.
![What do i do to 241 heads for more power?-forumrunner_20140601_160907.jpg](https://ls1tech.com/forums/attachments/generation-iii-internal-engine/454127d1469575866t-what-do-i-do-241-heads-more-power-forumrunner_20140601_160907.jpg)
they are a 66cc head ,maybe mill them down to 60cc.get a good valve job ,and have the springs installed correctly .advance induction ,and TEA do good porting .Texas Speed will port them also .maybe get a ls6 intake ,or a truck intake .the ls truck intake is better then a ls1 intake .
I would send those heads to TEA
https://ls1tech.com/forums/dynamomet...rwh-h-c-i.html
https://ls1tech.com/forums/11-second...new-setup.html
https://ls1tech.com/forums/10-second...-584-60-a.html
https://ls1tech.com/forums/generatio...-s-inside.html
I had a set of 241's I was matching with a 0.575 lift cam , sent them off to a good cylinder head shop, i wanted them fully ported but as per the advice the shop gave me when i showed them my cam specs they done a 3 angle valve job, milled 0.30 and done some bowl blending. Nothing fancy , was not expensive but had fabulous results and suited the cam very well. Compression bump was very noticeable. They could of ported them right out and charged $$ but they didnt see the need with cam I was using.
