BTR springs with comp cams compressor
Old Jun 4, 2014 | 09:24 PM
slowdenali's Avatar
Default BTR springs with comp cams compressor
I am hoping the someone can tell me I will get the hang of this or has some tips. This installer doesn't seem to work worth a **** to center the retainers making it next to impossible to get the retainers on.
Old Jun 4, 2014 | 10:46 PM
sick_0n3's Avatar
You have to move the springs as your compressing them to keep them centered.
Old Jun 5, 2014 | 12:37 AM
Kingc8r's Avatar
Mine went on no problem.
Old Jun 5, 2014 | 06:48 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Trial and error. If it seems the valve tips are going to hit the retainer, loosen, adjust, and try again. I had to do it too.
I used a small cordless drill with a socket at a slow speed so I didn't wear out my arm doing it. But yes, it works.
Old Jun 5, 2014 | 08:45 AM
thunderstruck507's Avatar
as mentioned above it's not just a matter of zipping them down, a large screwdriver might be required to wiggle things around a little
Old Jun 5, 2014 | 10:19 AM
slowdenali's Avatar
Great I was a little frustrated last night with it but I also has already striped the whole front of the car off changed the cam and alt and just wanted to try the first set of springs. I used to have a crane cams compressor and loved it but I let someone borrow it and it was never to be seen again. I thought I would give the comp a shot and first impression was this thing sucks I will try it again tonight when I get off work. Hoping to have it running by the end of the night.
Old Jun 5, 2014 | 10:27 AM
make sure you lube the ball end of the center bolt too, that helps keep it from twisting the bracket so bad
Old Jun 5, 2014 | 02:27 PM
slowdenali's Avatar
That makes perfect sense. I really was struggling with the twist of the tool last night lubing that end should help.
Old Jun 5, 2014 | 08:50 PM
dr_whigham's Avatar
The Scammer Hammer
Always lube the ball end of the center bolt...
Old Jun 5, 2014 | 09:32 PM
LilJayV10's Avatar
Quoted for truth.
Old Jun 5, 2014 | 09:54 PM
slowdenali's Avatar
went easy tonight almost ready to fire it up thanks for the help guys. It seems you can't use too much lube.
Old Jun 6, 2014 | 03:05 AM
geaganmang's Avatar
Old Jun 8, 2014 | 09:14 PM
c7monster's Avatar
theres no such thing as too much lube...
Old Jun 9, 2014 | 08:55 PM
gMAG's Avatar
For this, I always keep a jar handy at work.
