Serious damage during cam removal?
Scratches that run from the inside then travel directly across to the outside of the bearing edge are what you need to be concerned about. Verify that there are no raised ridges on the scratch borders, then run it.
If you never changed cam bearings in a LS1 then you wouldn't understand. It was minor damage, nothing to worry about. Its a cam bearing, its not that fussy. BUT installing a new one improperly will surely ruin your day-days...............
Cam bearings not that fussy? yeah right.. shitty cam bearing cause TONS of issues. Babbit bearings need to be spot free for more reasons than i care to sit here and type. If that where my motor i would have had that bearing out immediately.
Yeah those cam bearings are a ball of technical madness...............
please inform us of your technical diversity so we shall all profit from your truly amazing insight !
I've seen them worn down to the copper backing without a issue in sight.....so please tell me all perils surrounding a cam bearing with a few scratches on it?
Honestly I think most of you guys don't know anything BUT like to bark like a dog. I'll bet none of you even changed or even measured a cam bearing in your what 2-3 years of wrench turning.
I've worked on 1000's of engines...the BS stops at my computer screen.
Boys, boys....this is one of those times when an owner needs to decide for himself what is appropriate.
We make the decision, then live with it.
Thomas Paine..."These are the times that try men's souls..."
Yeah those cam bearings are a ball of technical madness............... please inform us of your technical diversity so we shall all profit from your truly amazing insight ! I've seen them worn down to the copper backing without a issue in sight.....so please tell me all perils surrounding a cam bearing with a few scratches on it? Honestly I think most of you guys don't know anything BUT like to bark like a dog. I'll bet none of you even changed or even measured a cam bearing in your what 2-3 years of wrench turning. I've worked on 1000's of engines...the BS stops at my computer screen.
I'VE seen tons of bearings failures in gas motors/hydraulic fracturing pump/ CNG compressors with as little as a scratch. How do you ask? contaminates in the oil collect in the scratch pushing oil out. Guess what happens next? The spot on the rod that passes over the oiless contaminated bearing scratch becomes hot.. do the math from there. Did it happen over night? no, but babbitt is a sensitive material that needs to be scratch/contaminate free.
ramble over.. just thought id throw that out there
F it I'm doing it live! Lol No honestly the pictures did not do it justice the bearing was not that bad at all and smooth to the touch. The worst of the damage and my biggest concern was the gouge in the block which doesn't come in contact with the cam anyway.
#32
Hey man at the end of the day it's your car! Just thought I'd share what I've seen in the past
#33
If the bearing got whacked and is loose or off in the block, If anything got in the hole, these things should put an end to the engine. Other than that at least change the oil before starting it and keep those fingers crossed. Best of luck to ya. You might get lucky.
#37
First make sure you get 3 long bolts to screw into the end so you have more area to control that sucker when you pull out (some guys use 1bolt I use 3). I pull out very slow trying to keep it level and a little twist back and forth. Really not much to it besides go slow and be careful.
#38
http://www.coloradospeed.com/durabon...6-p-32961.html
we got em very inexpensive! whole set but a good set!
I would rather be safe than sorry and have to pull it all back apart again OR have the bearing do worse things like spin or get damaged worse.
#39
Agreed but i cant help but open my mouth when you have morons like that guy saying faulty cam bearings don't cause issues and "ive seen tons of them worn down to the copper with no issues" Just becuase you've seen engines with run down bearings to the copper that is warrant for you to spread shitty advise? I think not
#40
that's all you got? Mr. Don't twist a cam when pulling it out.. I wonder how many of those "1,000" engines you've fucked up. Your the perfect example of "don't believe everything you hear on the internet"
