Serious damage during cam removal?
*UPDATE*
Completed the install and everything seems to be fine. Started up perfectly, runs, and drives with no oil pressure issues. For a dyno/idle clip check out https://ls1tech.com/forums/dynamomet...l#post18325468
You trying to remove the bearing and installing a new one along with honing it to proper size is just a basket of POO. I'd avoid it.
Please don't go sanding that bearing unless you want main bearing and rod bearing troubles. Those oiling holes lead right to the crank.
