Eagle 383 Stroker Kit
I agree on the Eagle vs Lunati concerns. Major spray, competition type stuff might make the Lunati and/or Callies items a little less of a price pinch. For me and my iron block LS1 creation the Eagle is just the ticket. Keith Craft builds some pretty mean motors using Eagle and swears by them ( of course this is after Eagle reworked their stuff ).
StrokedLS1, you mention clearancing the block for the rod bolts? All my info says staying at or below the 4.000" stroke means no block mods are needed? Hope this holds true as I do not want to make another trip to the machine shop!
With comments like the one I have set in bold and underlined above. I would take anything this person has to say with a grain of salt. The hardness of a metal has very little to do with it being "good".
The cast iron a potbelly stove is constructed from is hard to drill. That hardly makes it a good metal for a crankshaft.
Make no mistake,Eagle products are not high quality. Sufficient?Sure. I know there are alot of people making power with those parts. That still doesn't mean they are high quality.A watch from the dollar store will tell time.
There is a reason there parts are so much cheaper. To the best of my knowledge the majority of their parts are manufactured in China by companies with suspect manufacturing processes.
I'd rather spend the extra money to buy the product from a Company that uses known good materials in facilities staffed by knowledgable persons. Piece of mind is very important to me.
Reaaallly? how big of a cam are we talking here? How much would something like this cost? i have most bolt ons and i know my cam will have to go. Didnt expect that much hp and tq on stock heads though. Did you mean ported stock heads?
Would appreciate it if you can PM me the details. Thats the kind of setup im thinking about getting.
I think quite a few folks have been close to and above the 500 marker. Most of the magic is in the head/cam choice. The plus guys are in the 427 sleeved blocks by that time, tho. Still, lots of potential in the LS1 geometry. Just need to determine what your ultimate desires are and if the pocketbook will support it!
460 using stock heads in a 383 should be avarage as long as everyother bolt on is in place the tune is top notch the car is a 6 speed and the cam is in the high 230 duration or higher.
Are you talking 100% stock untouched LS1 heads? or ported heads? That makes a huge difference.
So lets say with a 383 stroker kit and ported stock LS1 heads and a cam like the MTI X1 cam (230 227 .591 .571 112) I should be able to do 430rwhp 430rwtq with the regular bolt ons (no fancy 90mm TB and LSX intake).
Is this true? or anywhere near possible?
You dont need the extra cubes if this is all you are trying to achieve.
Just do a nice heads and cam package, headers, exhaust and all the bolt on's with a good tune and you will be there with stock cubic inches.
Go check out the dyno section and see what it takes to make that power in a H/C car. It is quite easy.
There are many making that power with stock unported LS6 heads.
I personially am not a huge fan of that cam as I believe something like the F13 would be a better porew provider while suffering very little driveability differences.
It is a 230/232 58x/ 59x if my memory is correct.
Another cam I will say gets good reviews that is large is the G5X3.
Call a few companies. Start with the sponsors to your right.
Call Absolute speed/PP/TEA/LG motorsports/MTI/Thunder/ etc.
That will get you in the right direction.
You dont need to spend the 5 thousand + dollars on a 383 shortblock. In all reality you are about 3000 dollars away with your current setup.
