427 Ci
Old Jun 8, 2004 | 11:30 PM
waterbug1999's Avatar
Default 427 Ci
Can you achieve this with a LS1 block? Would like to start a project but dont know where to start.. Heard the 427 is the ****.. Thanks!
Old Jun 8, 2004 | 11:38 PM
Futral's Avatar
Yes you start with LS1 or LS6 block and have it converted to a wet sleeve setup to achieve a 427. I will forward you some pricing if you are interested
Old Jun 9, 2004 | 12:34 AM
What do i need first?
Old Jun 9, 2004 | 12:41 AM
jrp's Avatar
jrp
SN95 Director
have some serious bank
Old Jun 9, 2004 | 06:41 AM
Bear's Avatar
4.125 LSx Block and a 4" stroke=428
I call mine a 427 just, because.
Old Jun 9, 2004 | 08:29 AM
With a new job coming up i will have an extra 1500 a month to blow on the TA. Where do i get a block at first? Need to do it in steps because real bad at saving money. Figured id buy a block first then a package for the internals (stroker kit). Was going to go with a 383, but figured the 427 will not be that much more money or wil it?
Old Jun 9, 2004 | 10:08 AM
dand35th's Avatar
It will be about $2200 or so more.. for the sleeves and machining and installation of them.
Old Jun 9, 2004 | 10:39 AM
Nasty N8's Avatar
The 427 will be about $2500 more than the stroker the only difference will be the block and some extra porting on the heads. We are seting up a couple of 427 Darton sleeve blocks at the moment. Let me know we can get you some pricing.
Nate
Old Jun 9, 2004 | 10:47 AM
2MuchRiceMakesMeSick's Avatar
Please PM me some pricing as well
Old Jun 9, 2004 | 11:46 AM
BurnOut's Avatar
So, comparing a stock block/crank (forged) motor to a stroker to a stroked/bored setup (like the 427), the price breakdown goes like this, correct??
Stock block/crank- forged rods, forged pistons, balancing
Stroker- stroker crank, forged rods, forged pistons (I assume that the cost would be roughly the same as forged pistons in the stock block/crank motor), balancing
Stroked/poked- sleeved block, stroker crank, forged rods, forged pistons (again, I assume that the cost would be roughly the same (within a couple of hundred dollars) as the pistons for either of the other two applications), balancing.
Or am I missing something?? Let's say that you could find a stroker crank for $1k, and a sleeved block for $2500... since we're assuming that rod/piston cost for each motor is the same (also assuming that balancing costs are in the same ballpark), does that mean that a 427 (short block) could be assembled for ~$3500 more than a forged 346??
Obviously, heads to match the 427 are going to cost a bit more, but other than that... or is there a whole mess of other machine work that has to go into the 427??
Old Jun 9, 2004 | 11:53 AM
Nasty N8's Avatar
You about got the general idea.
Nate
Old Jun 9, 2004 | 01:16 PM
Bear's Avatar
You better make sure your #8 piston clears the reluctor wheel or you will have one big mess on your hands, KINDA LIKE ME.
https://ls1tech.com/forums/generation-iii-internal-engine/177740-jpr-427-coming-apart-literally.html
Old Jun 9, 2004 | 08:11 PM
angst911's Avatar
https://ls1tech.com/forums/showthread.php?t=177740
you'd also be sure whoever assembles it knows how to check bearing tolerances and ring fit.....
Old Jun 9, 2004 | 08:20 PM
hugger427's Avatar
IMO and based on experience, who ever you select to build your engine, have them do the install and tune (turnkey). Eliminate finger pointing. Also go with a shop that has been in business for several years...do not do dry sleeves, consider the C5-R block.
Old Jun 9, 2004 | 09:16 PM
angst911's Avatar
or darton wet sleaves...... dry sleeves... yuck..
By Brett Foote | 2026-06-04 05:00:17
