LS Starter question
Old Jun 19, 2014 | 11:14 AM
jasonz28camaro's Avatar
Default LS Starter question
I have a 6.0 motor I am putting in my 96 SS and I do not have a starter. What is the best starter to buy considering the size/ weight, price and performance? Do ls2 and 3s fit or are they any different?
Also, I have my old lt1 starter. I did a few searches on it and some say it will work and others say it will not.
Thanks!
Old Jun 19, 2014 | 11:23 AM
MX6.0's Avatar
It depends on what bell housing you have. IIRC, the GTO bell housing is different and only allows GTO starters to fit due to the nose cone of the starter.
That said, an aftermarket starter without a nose cone will fit just fine. I'm using THIS one and haven't had any issues at all.
Old Jun 19, 2014 | 03:33 PM
JakeFusion's Avatar
Super Hulk Smash
Go with the later model trucks, LS2, or LS3 (need to splice the wiring from what I understand) to get the updated braketry so the starter doesn't break off and take a piece of block with it.
Old Jun 19, 2014 | 08:24 PM
poltergeist 02's Avatar
I bought an 04 Tahoe starter for a 5.3 and it's actually smaller with a factory gear reduction. Much better starter than the factory 02 f body starter.
Old Jun 20, 2014 | 10:50 PM
Sorry, I thought I sucribed to the thread.
Its a 4L80e bellhousing.
As far as the splicing goes I am having a bp automotive harness made for me and I could probably get it made for whatever starter i think?
Old Jun 20, 2014 | 10:51 PM
Did not know there were different brackets, i need to look more into it.
Old Jun 20, 2014 | 11:27 PM
01cherryreds10's Avatar
This is the answer right here. I bought a car shop starter because it was cheap, and when it crapped out I stole the starter off my dad's 06 5.3 silverado to make sure it was a starter. It's light, small, and does the job every time.
You can get them at a auto parts store for under $200, or go to the dealer and pay over $500
Old Jun 21, 2014 | 12:04 AM
It will bolt and wire right up correct? Just need to grab truck bolts too.
Old Jun 21, 2014 | 02:07 AM
dorcewangy's Avatar
Old Jun 21, 2014 | 07:14 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Here's the later bracketed starter that you want:
Old Jun 21, 2014 | 10:09 AM
Thanks. I'll start looking for a good deal on one.
Old Jun 21, 2014 | 03:34 PM
chevybayboy's Avatar
Yup listen to Jake I got to buy a starter bridge to fix what the starter broke
