Compression options on LS2 build
Old Jun 27, 2014 | 10:46 AM
turboost's Avatar
Default Compression options on LS2 build
I'm finishing up a stock bottom end rebuild on an LS2. I have a pair of used TEA 243s that I had CC'd and came to 68cc. These heads matched up with stock gaskets come to ~10.5 CR. This will be a DD on 91 octane but I want to maximize its efficiency/torque. How much more compression can I go for, if any, and what would be the best way to go about it? This will be paired with an EPS 226/230 cam and the piston at TDC is above the deck .010.
Old Jun 27, 2014 | 12:02 PM
redtan's Avatar
Well definitely get back to at least the stock compression ratio if not slightly more.
No reason to go below that and even lower SCR due to the cam.
Shoot for 11.2-11.3 and get some thinner headgaskets for better quench.
Old Jun 27, 2014 | 04:10 PM
yonerhottlt1's Avatar
I thought 243 heads were 64cc stock which would produce 10.9:1 compression on a stock LS2. Does TEA open up the combustion chamber that much?!
Old Jun 28, 2014 | 12:09 AM
turboost's Avatar
Appearently so. Their website says 67cc, my builder measured 68cc. What is a comfortable compression to be at with this cam and 91 octane? And is milling the head a better route than thinner head gaskets? Are the thinner head gaskets reliable? Would I be better off with a head that flows a little less but has a smaller CC?
Old Jun 28, 2014 | 06:18 AM
redtan's Avatar
Mill a bit and use thinner headgaskets. The thinner headgaskets have more benefits than just lowering compression. Like I said before, shoot for low 11s with that cam.
Old Jun 28, 2014 | 04:15 PM
turboost's Avatar
Any problems with installing cometic .040 gaskets? Are they the only ones who make a thinner gasket?
Old Jun 28, 2014 | 07:15 PM
RezinTexas's Avatar
Measure your piston-to-deck height and shoot for 0.035-0.040" quench. That will tell you what head gasket to use
Old Jun 29, 2014 | 10:44 AM
KCS's Avatar
KCS
Moderator
If you're pistons are .010" above the deck, a .040" thick gasket will put you at .030" which is too close, I think.
Your cam is small enough that you can probably get away with milling down the heads and reducing the chamber volume. That's really the only options you have. If you wanted more compression, a ported 5.3L head may have been a better idea.
Old Jun 30, 2014 | 03:12 AM
turboost's Avatar
I have some PRC 5.3s that I could use but I like the idea of the extra flow of the TEA 243s. Would the extra compression from the 5.3s be more beneficial than the flow of the TEAs?
Old Jun 30, 2014 | 05:48 AM
redtan's Avatar
No because you can get that compression from the TEAs also, just need to mill em' down.
Old Jun 30, 2014 | 09:54 AM
KCS's Avatar
KCS
Moderator
At 68cc, that's going to be a lot of milling, which will eat into PTV clearances and run the risk of causing a port mismatch with the manifold.
It's not like you can't mill the 5.3L heads either.
IMO, the compression will do more good for overall power.
Old Jun 30, 2014 | 03:20 PM
turboost's Avatar
According to the calculations if I can get the heads to 64cc I'll have 11:1. Would this be a enough compression? How much milling would it take to get 4 cc off?
