need some serious help...
Old Mar 12, 2003 | 11:18 AM
black00WS6's Avatar
Default need some serious help...
I posted this in the LT1 section but no responses...hopefully there are some LT1 lurkers in this section.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
ok, I've been working on my friends LT1 for about 7 months now. We've had the heads off 3 times now due to the fact the guy that ported his heads put the wrong spring seats on (long story), but finally we got it to run!! Now after we set the valve lash, there is a ticking on the passenger side. We think its a bad lifter. Is there anyway to tell before we start tearing it down again? I believe he has some computer software to scan it. Any suggestions??
Thanks
John
Old Mar 12, 2003 | 04:46 PM
LOnSLO's Avatar
Default Re: need some serious help...
You mentioned valve lash. Is this a solid roller setup? If so, then it's not a bad lifter, since they're pretty much indestructable. If this is a hydraulic setup, what spring pressures are you running? Need some more detail.
Old Mar 12, 2003 | 05:22 PM
black00WS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LOnSLO:
<strong> You mentioned valve lash. Is this a solid roller setup? If so, then it's not a bad lifter, since they're pretty much indestructable. If this is a hydraulic setup, what spring pressures are you running? Need some more detail. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No its a hydraulic roller. It's the CC306 cam, and I'm not sure what springs he has. They resemble the 987's. He also put in crane 1.6 roller tipped rockers as well.
Old Mar 13, 2003 | 12:57 AM
black00WS6's Avatar
anyone?
