00" silverado 222/224 cam problem
Old Jul 13, 2014 | 07:46 PM
Isaiah_13's Avatar
Default 00" silverado 222/224 cam problem
So I have a 00" silverado that I done a cam swap on. It's 222/224 comp cam. stock stall for now, with 3.42 gears, stock injectors. The truck is tuned with hp tuners, the problem I'm having is at low speeds like 15-20 mph when I really get in the throttle, my wideband will read 20.00 on the lean side, and I'm basically not going anywhere and you can hear the motor pop like it's blowing a plug... Is this a problem with the tune or something mechinal ?
Thanks
Old Jul 13, 2014 | 08:15 PM
PhoneniX's Avatar
It would help for readers to know what rpm this popping happens at. Based on what i've read a otherwise stock drivetrain will have little issue with a 224/228 cam. The fuel injectors will be above the (now seemingly controversial) 80% rule of thumb duty cycle. But they SHOULD still be effective enough until n2o or intake/head work is added.
My reaction is a poor initial tune.
Old Jul 13, 2014 | 08:18 PM
Isaiah_13's Avatar
Sorry about not mentioning the rpm, I haven't really looked at the rpm when it happens to the wideband. So my injector duty is almost maxed out right?
Old Jul 13, 2014 | 09:31 PM
Always2Slow's Avatar
Do you have HP tuners and a wideband or just the wideband?
Old Jul 14, 2014 | 06:35 AM
Isaiah_13's Avatar
I just have the wideband my friend tuned the truck he has the hp tuners
Old Jul 14, 2014 | 11:15 AM
PhoneniX's Avatar
on researching for my stock 2000 26lb injectors word of mouth is they are at 90/95% duty cycle with a cam and expected 380-400rwhp
Old Jul 14, 2014 | 06:30 PM
Isaiah_13's Avatar
So do I need bigger ones or a better tune? I don't know a lot about tunning
