cam advice
Old Jul 17, 2014 | 09:59 AM
slammin sammie's Avatar
Default cam advice
Started tear down of budget LS swap. i have a 2002 LQ9 motor with 317 heads, all stock. I am planning on placing a LS2 intake on with a DBW TB. This is going on a frame off 1981 corvette with a 4l65E transmission and a rebuilt standard rear end that was completely rebuilt. As i still have the fuel system and body of the car to work, funds are rapidly running into the yellow quickly. I am looking for someone to advise me of what cam shaft would be best for my selection. Gonna be a daily driver and wanting a nice mild chop nothing radical. Not looking to race but want it to go when i give it the gas. Also will I need to change out the valve springs and roller lifters or can i just make the cam swap. Cylinder walls of block have no wear and still show a cross hatch. Not wanting to remove crank or pistons as they look immaculate. i will be running long tube headers. Any and all advise is appreciated.
Old Jul 17, 2014 | 12:22 PM
Exeodus's Avatar
Contact Martin at Tick Performance for a recommendation. If the lifters are in good shape, you can get by with them, but if the heads are already off it is a good idea to change to LS7 lifters at a minimum. Valvesprings and pushrods are a must.
Old Jul 17, 2014 | 12:29 PM
Rise of the Phoenix's Avatar
Sounds like your in the ballpark for something like the Streetsweeper High Torque cam. 228/232 and 111 LSA. Not too big, easy to daily drive (with the right tune) and will have nice lope with 8 degrees of overlap. Or, you could go with the 228r cam. There are quite a few shelf cams that are designed for daily driving, but will give you a nice, noticeable idle.
Old Jul 17, 2014 | 12:55 PM
DANOZ28's Avatar
since its a daily driver a slightly milder cam a sponsor here has on sale $370 colorado speed 224/228 with only 551 lift on a 114 lsa. wouldn't be a bad choice. also the poster above tr228. cheers.
Old Jul 17, 2014 | 03:49 PM
99Bluz28's Avatar
You'll need to start with a High stall TC first, in the 3200-3600 rpm stall range.
for a 228 cam I'd look at the Speed Inc., TU1.5 cam which is a 228/228 112lsa with the milder XE(high lift) cam lobes. It is listed as a turbo cam, but it will work very good in a NA application with LT headers.
http://www.speedinc.com/shop-by-vehi...m-228-228.html
Another nice cam for Tick.
http://www.tickperformance.com/tick-...1-ls6-engines/
Between these 2 cams I would lean towards the Tick cam.
Old Jul 17, 2014 | 03:56 PM
whatsa347's Avatar
A nice stall and a 220/224 on a 111 lsa would be nice. Some BTR platinum springs, lunati trunion, lunati lifters, Hubbard ls6 pump, ls2 chain, decent tune and rebuild that tranny because you'll need it sooner than later if you beat on it. Other than that have fun with it, should be a nice setup, and a reliable "set it and forget it" kind of swap.
Old Jul 17, 2014 | 05:48 PM
cuisinartvette's Avatar
You guys realize his Vette probably has a super tall 2.xx rearend gear? (if its the stock one)
Old Jul 17, 2014 | 08:35 PM
99Bluz28's Avatar
Well if that's the case, then I guess he's going to need rear gears also.
Old Jul 18, 2014 | 06:35 AM
Default differential
Thanks for all the input. It does have the stock rear end with the bat wing carriage mount. Is that going to cause me a problem? And again thanks for the advice from all
Old Jul 18, 2014 | 10:26 AM
Exeodus's Avatar
It won't cause a problem, but a high ratio (low numerical) gear set will make the car feel lazy off the line, but combined with the overdrive will make a great cruiser and have decent fuel economy. A high stall converter will help it get off the line faster, I would go with at least a 3600. Also the 4L65 has a low first gear (3.06 IIRC), which will also help.
Old Jul 18, 2014 | 12:24 PM
COSPEED2's Avatar
LS1Tech Sponsor
We do have our custom cams for the same price right now. All Comp pricing went up. But we can custom spec you a cam you will be happy with also!
