#7 cylinder melted side of piston
Old Jul 21, 2014 | 06:49 AM
ifixkars's Avatar
Default #7 cylinder melted side of piston
I have an 02 ls1 that melted #7 piston when I took engine out and disassembled it I didn't see any damage in cylinder so I ordered a standard engine kit I then put top ring in cylinder to check end gap to find it at .035 so my question is since that is only cylinder that is wore could I get away with installing a .010 oversized set of rings and grind to fit them or will I have other problems
Old Jul 21, 2014 | 08:46 AM
svede1212's Avatar
Melted #7 is fairly common when you're running on the lean side. I'd look at the AFR. If you get your injectors flow rated always put the richest one on #7. Don't understand why that cylinder would have "grown". Have you measured the bore besides comparing to that ring?
Old Jul 21, 2014 | 06:05 PM
joecar's Avatar
Pics...?
Old Jul 21, 2014 | 06:32 PM
ifixkars's Avatar
I measured cylinder and its at 3.909
Old Jul 21, 2014 | 07:01 PM
LS1MCSS's Avatar
That's .011 over. Measure the other cylinders too. Something is up with that engine.
Old Jul 21, 2014 | 07:44 PM
svede1212's Avatar
Sounds like it's been honed out before. . .
Old Jul 24, 2014 | 06:40 PM
ifixkars's Avatar
ok so I got a set o je pistons my next question is what kind of clearance should there be for a set of forged pistons
Old Jul 24, 2014 | 10:08 PM
Old Geezer's Avatar
Ask JE. They have specs for such.
Old Jul 25, 2014 | 01:42 AM
RockinWs6's Avatar
How could you buy pistons without knowing your clearances?
