Lq4 question
Old Jul 30, 2014 | 07:00 PM
silverado.408's Avatar
Default Lq4 question
Kind of beating a dead horse. I'm running a LQ4 in my truck 4200 lbs. I have had a cam sitting around for a while ( 235-243 .620 .623 111) My question is how well will the lq4 respond to p&p 5.3 heads with the higher compression vs cleaned up 243 heads and that cam. I might play with nitrous and I'm in Colorado springs where the standard altitude is 6500 ft and DA can average 8000. Any input would be helpful. The rest of the truck is th400 3600 stall and 3.23 gears 28 inch tall tire. Thanks in advance ( yes I did use the search didn't really help )
Old Jul 30, 2014 | 07:25 PM
HCI2000SS's Avatar
Just for reference I'm running A LQ9 with PRC 5.3 heads with a cam very similar to the one mentioned above. Compression is 11.5:1 and it runs pretty damn strong for that setup.
Old Jul 30, 2014 | 07:35 PM
If Im thinking right compression should be in the 10.5 ish range correct ?? So I should be good with that cam cleaned up 5.3 heads and a little bottle (200 shot) ? Trucks not an all out build yet just a play toy.
Old Jul 30, 2014 | 07:39 PM
HCI2000SS's Avatar
Well all I can tell you is that it works great in ride, and responds great to nitrous as well. Will this be a stock internal LQ4 then?
Old Jul 30, 2014 | 07:43 PM
Yep. I will replace rod bolts and valve train to keep up with the new stuff but other wise stock.
Old Jul 30, 2014 | 08:32 PM
96capricemgr's Avatar
needs more gear for that cam.
Old Jul 30, 2014 | 09:22 PM
brandon6.0's Avatar
I have a very similar setup. same cam. runs like hell and even better with nitrous. more gear for sure.
Old Jul 31, 2014 | 05:34 PM
Input on gear recommendations ??
