6.0 pulling truck engine build help
What I am wanting to do is build the top end of the motor. I want the most compression I can get and ill be running E85. Need some help on picking heads and cam.
The problem is that the class I run has to be stock in appearance. I have a tbss intake that I am porting with 90 mm throttle body. And thinking of some kind of corvette manifolds. Any ideas?
If you can't put headers on it, that's going to REALLY hinder your ability to make power, because in NA form, you need the best breathing engine you can get, which isn't going to happen with manifolds. Too bad you can't run headers and then a single plane intake and 4150 TB with a wicked cam and some really high end heads, like TFS, AFR, or MAST. Compression wise, I think you could get away with 14.5:1 or maybe even higher on e85. Some more details would be great. Sounds like a pretty cool build though. I love pull trucks. Just never seen a LSx pull truck.
