Rocker arm rubbing valve spring cap
As others have stated, you need to take a bunch of measurements to figure out the exact problem and go from there.
What is the setup?
I have a brute speed blower cam the specs on that are "dur @.050 232int/240exh lift .595int .608exh lsa 115"
comp 7955-16 pushrods 7.40"
comp 26926-16ts valve spring kit came with springs,retainers,valve locks,valve seals, and spring seals
stock rockers
comp 3153kt timing chain
heads and everything else stock as far as i know.
also im going to order the micrometer and start measuring everything asap
they do look a lot different then yours though.
I asked Bob at brute speed and he sent me a link from comp it says 1.835 install height is 1.8 a lot more common? I just have the seat and no spacers under it
If you had this installed they could have shimmed them up to the right installed height for the springs as the retainers can have a +.100 installed height and that will cause clerance issues with the rockers
If you have a part number on the retainers only,that would help identify and eliminate some possibilitys
Yes the retainers are to high, but why...?
