Catch Can Help - MightyMouse Black Series
I just got my mightymouse black series PCV model and I have just one question for the install. I have a 99 LS1 and my current routing is: metal pcv in back side of drivers valve cover in a gromet and the port on the back of my ls1 intake is capped, 3/8" running up to the intake port behind the throttle body and a separate line from passenger valve cover to throttle body port.
My question is since I bought the model with a pcv built into it do I pull that metal pcv out of the grommet on the valve cover and if so what do i put in its place.. do they make just a dummy pcv that's wide open? something that will seal into that rubber grommet on the valve cover hopefully and hook into 3/8" line.
any advice is appreciated.. and yes I searched i just couldn't find anything on this specific can or scenario. thanks
Edit: wow wrong forum someone please move
