View Poll Results: Comp Trunion issues vs non issues
issues with them
10.00%
no issues with them
90.00%
Voters: 20. You may not vote on this poll
Comp Cams Trunion issues vs non issues
Old Sep 3, 2014 | 11:25 AM
FirstGen F-Body's Avatar
Default Comp Cams Trunion issues vs non issues
Everyone that has or had Comp trunions
How long have you had them installed?
Have you had any issues with them?
If you had an issue with then what was it?
Iv heard a few people say that their junk and others swear by them, so i figured it would be a good to get some numbers of issues vs non issues for people on the fence about getting them.
Old Sep 3, 2014 | 11:26 AM
VandykeT/A's Avatar
I've had them a couple years and no problems. Probably 10k miles.
Old Sep 3, 2014 | 11:57 AM
whatsa347's Avatar
How many people have actually had bearings come out of their rockers? Also what are the differences between Comp, Lunati, and Summit trunnions?
Old Sep 3, 2014 | 07:22 PM
74u's Avatar
74u
No issues, but only 3500 on motor.
Properly installed I bet the vast majority don't see any problems.
Old Sep 3, 2014 | 08:07 PM
99Bluz28's Avatar
Several yrs and about 12k miles no issues with Comp trunion up grade, and I dd my car. The upgrade is fairly fool-proof, but it can still be screwed up if you make the mistake of think it's 110% fool-proof.
BTW, Harland Sharp also makes a trunion upgrade kit.
Old Sep 3, 2014 | 09:47 PM
mjs1012's Avatar
Mine are fine but I only have about 3k miles on them. As long as you install them correctly, there shouldn't be any issues.
Old Sep 3, 2014 | 11:00 PM
dodson55's Avatar
I had a set ran them about 8k miles went to do a head swap and found that the trunions and bearings were wore out, if your car don't see a lot of miles you should be fine with them but if you dd your car don't expect them to last long
Old Sep 4, 2014 | 08:42 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I put around 13k? on mine I believe... a yrs worth of daily driving, and a lot of long trips. Frankly, I beat the hell out of the car, and it took it without a single issue.
Ran them with a stick from Ed Curtis, a 229/236 .631.631 with no issues, AFR 205 heads, bronze guides, LS7 lifters and LS2 trays.
I also changed my oil every 3k miles regardless of the color, still gold or not.
I ran Castrol Edge (gold bottle, not black) 5w30, and a Wix 51522 (longer filter) and the filter was always changed with the oil.
I did run Valvoline VR1 for a little while; both the synthetic and the conventional.
I went back to the edge bc it's the only oil (4 different LSx motors / vehicles now) that made the valvetrain damn near silent.
Old Sep 4, 2014 | 09:14 AM
toadzq8's Avatar
I have done 22 sets of these with out any failures. Using the correct assem dies to press the bearing in and set end play to .008-.009 plus use assem lube you should not have any issues
Old Sep 4, 2014 | 10:26 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
I have done probably 15-20 sets without any issues and I have had them in my built 6.0l LQ9 in my truck for close to 25k miles without any kind of issue. I generally like to recommend them with any motor that has a bigger aftermarket cam in it.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Sep 4, 2014 | 12:55 PM
whatsa347's Avatar
Honestly I might just buy a set of stock rockers for cheap and send them in to Harland Sharp for their trunnion (basically the same thing right?) because from the sound of it, setting them up right is key and I'd rather have a company that makes rockers set them up for me.
Old Sep 5, 2014 | 08:22 AM
LS1-450's Avatar
Regardless of upgrade/no upgrade; if you have an aftermarket cam that requires higher than stock loaded springs, the rockers should be visually inspected twice a year or every few thousand miles depending on how often the car is driven.
I tack weld the stock bearing covers on & have even had one of the tacked covers fail where the tacked section held & part of the cover where there was no tack weld snapped off. This is not related to the "rocker upgrade" in question, but demonstrates the added loading experienced by the rockers. Even though the upgrade is an excellent mod, upgraded rockers can & have @ times failed. It's far less likely, yet still need to be visually inspected from time to time. It's simply part of owning a modified engine.
Old Sep 13, 2014 | 01:22 PM
I figured there would be very few issues.
