piston question??
Old Sep 8, 2014 | 08:16 PM
busha61067's Avatar
Default piston question??
will these work on a stock stroke lq4https://ls1tech.com/forums/attachment.php?attachmentid=468297&stc=1&d=1410225 291
Old Sep 9, 2014 | 01:11 AM
64post's Avatar
Not for stock stroke with that CH (1.115), those pistons are likely for 4.00 stroke and 6.125 rod length, 408-410 etc.
Old Sep 9, 2014 | 06:46 AM
Tomis's Avatar
They can work, as long as you get proper length rod. You could go with 6.250 rod and you will end up with 0.064" quench if shave the block then another 0.024" you had it all set up.
I guess I would be cheaper to get other pistons unless you get them for free.
Old Sep 9, 2014 | 08:13 AM
busha61067's Avatar
i haven't bought the rods yet so if I get those length rods I can still use stock crank correct?? I found an awesome deal on these.. would anything else need to be changed
Old Sep 9, 2014 | 08:23 AM
KCS's Avatar
KCS
Moderator
6.30" rods would probably work better and not have to cut as much off the deck.
1.115" + 1.811" + 6.30" = 9.226" Deck Height
Old Sep 9, 2014 | 09:06 AM
busha61067's Avatar
so the correct length rods and shave the deck a little and everything would work fine correct
Old Sep 9, 2014 | 06:46 PM
busha61067's Avatar
bump. anybody??
Old Sep 9, 2014 | 07:30 PM
Violence.z06's Avatar
what stroke crank will you be running?
also may want to look at the valve reliefs and see what heads they were made to work with
Old Sep 9, 2014 | 10:32 PM
busha61067's Avatar
stock 3.622 stroke
Old Sep 10, 2014 | 02:45 AM
Tomis's Avatar
Yep that is more close, looks like I put some wrong figure in my compression calculator .
Old Sep 10, 2014 | 05:27 PM
yea would need a longer then stock rod. or use a 4" stroke and a 6.126 rod
