LS1, 241s and MS3 combo
I don't race track enough to really consider nitrous a real benefit. I do drive it daily and want a fun daily capable driver with weekend track capabilities. So now I'm thinking I should prolly cam it, use the 853s that are on it and sell the 241s towards something else or save until I can get some better heads. I think that's the deal. I have everything needed to assemble the heads, dual springs, new chromemoly push rods, retainers, locks, new seals...I guess I will just be doing that IN THE CAR...Man that sounds like a job.
EDIT: Found my answer via Search. Will clear fine. No need to check PTV with clay
I like the idea of AI HCR 241s... they weld the chambers and keep the stock valves to bump the compression without affecting clearance. And the MS3 really needs compression - a lot of compression. Like 11.8:1 to run optimally. So 58.5cc chambers and a .040" gasket paired with an MS3 would be beastly with AI's port program.
