Cam that will not smell of fuel
What sort of overlap do I need to shoot for to just about kill any trace of smell while driving?
Edited for valve events:
What I'm trying to figure out is how much sooner do I have to close it in order to eliminate the smell? I updated the first post with the current valve events I have.
I did play with EOIT and have it advanced quite a bit more than 20* (at idle at least). Is going too advanced going to make it worse?
Also, have played with timing and right now it idles in the low-mid 20s. Why do you say no more than 20* of timing?
O2s are new and switching properly, although STFTs are in the -8 to -12 range. AFRs however are very stable in the mid 14s all the time.
Increasing the idle spark timing raises the combustion temps thus increasing Nox. With your cam, I would use 16-18* idle spark timing.
Russ Kemp
So is there a downside to too much delay (I have it at 60* idle and tapers off by RPM)?
Also I thought that lower timing values meant hotter exhaust. It's when you have like single digit timing that you start seeing headers glow no?
I will try to lower the timing a bit, but I remember when I had it down to like 13* the car chopped hella hard and it really stunk. Increasing the timing seemed to have helped, but maybe I went too far.
And like I said, AFRs monitored by the wideband are dead steady in the mid 14s so not too worried that it's running lean or rich.
What do you usually have the timing and/or EIOT set at for those cam swaps that you said didn't smell?
My high flow cats are 5 years old and I need to replace them soon as the exhaust is starting to smell. Probably due to the piston/block damage that filled the cats with antifreeze.
Lower timing does increase the exhaust temp, but lowers the combustion temps thus lowering NOx. NOx is what makes your eyes water and gives off the nasty stink.
What is your idle speed? As too low can increase the exhaust odor due to the inefficiency of the combustion at low RPM. I would set the idle at 900-950 RPM.
Russ Kemp
650 was alittle rough, 700 is pretty smooth so far.
What makes it too low? It idles pretty smoothly at those RPMs so I always thought that the lowest value that it can hold idle is best.
And reduce the Normal EOIT Target Adder vs ECT by 20* (all temp cells) and leave the other Injection Timing tables stock.
And set the idle spark timing to 16*, after doing all this if the exhaust still stinks, replace the cats. Kooks has the green cats that might be better as they are 49 state legal.
Russ Kemp
