5.3 with tsp224r cam?
ls6 oil pump (ported preferably)
new springs
hardened pushrods
you have to pull heads for lifters, so I would steer away from that unless you upgrade heads too
you will need a good street or dyno tune and a higher stall aftermarket torque converter for that size cam IMO
if you don't want to touch the converter, get a smaller cam and all the same above still applies unless you go down to something real small like the Cam Motion drop in cam I run (it only really needs cheap ls6 valvesprings for $40 and a tune) but the other stuff isn't a bad idea anyway
new springs
hardened pushrods
The absolute biggest I would go on a stock converter would be something like Brian Tooley's stage 2 (212/218 iirc).
I really like my Cam Motion drop in truck cam, picked up huge power in the places I use it...idle to 6000rpm. And even with it, the truck really wants either a slightly larger converter or some 4.10 gears to really wake it up.
Mine is the Cam Motion Stage 2 drop in cam. See this thread for dyno, full review, and sound clip: https://ls1tech.com/forums/dynamomet...hp-22rwtq.html
