Best intake for me
If you go with the 92 you can reuse your stock fuel rail/injectors. Except for changing the valley cover bolts and steam tube it's pretty much a bolt in.
With the 102 you will either have to get an LS2 fuel rail or aftermarket. Depending on what injectors you use you will either have to get spacers for the fuel rails, two different sized injector o rings OR get wiring adapters; LS1 and LS2 injectors use different plug ins.
You will either have to grind your waterpump and/or T/B for clearance issues or use a water pump from a LS2 GTO.
IMO, FWIW the extra cost with getting a 102 is not worth the minimal gains on a stock headed motor.
Which leads me to my next thought. Keep your LS6 intake and either buy a set of heads of have your heads ported. You will see a much larger gain from the improved cylinder heads even stock 243's
A good set of ported stock heads(depending on what you go with) is going to be about the same price as a 102 and all of the other things that go with it.
Just my .02
The nice thing about today is that people are over paying for ls6 intakes. I just sold my ls6 after I got my fast on, on ebay with the tb and rails it sold for $650 plus shipping and hte sad part is that wasnt uncommon from what I saw on there. With prices like that the FAST isnt such a bad deal.
With that said the 102 will make a tad more power but the 92 would allow you to keep your injectors and fuel rails as well as not have to relocate the MAP sensor or grind the wp.
Depending on your drive train setup I would expect to see 420-430hp w/ some killer torque.
