lifted hot rod
I have an 03 gmc 1500 with a 6inch lift and 35" tires and the truck has around 135,000 miles on the stock drivetrain and motor. I want to make this truck fast but dont know if its worth modding out the motor because of the mileage. plus I live in california and would still like this thing to be street legal as far as emissions goes. So im trying to build up a lifted truck with ls motor being able to put out as much power as possible. Any suggestions would be great. Thanks
That being said, as long as you have maintained it, 135K is just getting broken in for a good LS motor so mod away. Plenty of guys here putting heads and cam on LS1s with 150K+ miles.
With a lift and tires on a relatively heavy vehicle, your best bet to make your truck peppier is gears. Doesn't sound that exciting but this will make the single biggest difference in performance right now. Then get a basic tune and go from there. Gears and tune should at very least make the truck a lot more fun to drive.
Good luck with your truck.
http://www.dragtimes.com/gear-ratio-...-mph-speed.php
That way you can put in your specs and figure out where you need to be.
BTW, what engine do you have..?
Big heavy trucks need torque, lots of it.
H/C can help but imo not worth the money spent in comparison to a SC $ to power.
Have the same truck (2wd) unless theres a power adder not sure its worth going H/C trying to pass smog and getting the gain SOTP youd hope for.
If you cam it keep on the smallish side.
Theres a truck in town similar to yours, pretty much stock but S/C it moves out real good.
Positive displacement(the kind that replace the intake manifold, like the "Maggie" I mentioned) (not centrifugal that hang on the front of the motor) give you boost basically right off idle and that's what will make your truck feel FAST...like basically a 7.0L instead of a 5.3L. A Procharger or similar centrifugal supercharger will make impressive mid-high RPM power but you'll find yourself counting the seconds on your fingers at the light waiting on your boost to get in order. Need a big stall and a light car to make that fun IMO.
Agree with the others on 4.56+ gears if you want to be fast. Just run the calculator and figure out what MPH your shifts will be at and what RPM you will be running at highway cruising speeds in overdrive.. Then imagine yourself in the driver seat with shifts happening at those speeds and those RPMs(determines noise level) at cruise speed and figure out if that makes for an enjoyable driving experience.
It occurs to me that heads/cam/intake/exhaust/etc. would wake things up a bit and sound badass but since you have a relatively heavy vehicle and a relatively small motor, would make a lot of noise and only feel marginally faster and mostly only at high RPMs. It is still a way to go but the positive displacement supercharger will make you forget all about the money you spent the first time you hit the gas...and have the most streetable and fun power band. My last car was a 04 comp orange Cobra. Factory pos dis supercharger..and a bunch of other goodies. There is no describing the **** eating grin you get on your face when you're passing someone on the interstate at 70 in 3rd gear while smoking the tires. And then the look on their face when they see the smoke..and hear the whine of the blower!
In all fairness, overdriven Eatons are loud as **** in a really good, intimidating way, but you get the idea.
Still, the positive displacement blower will always make more power at low RPMs compared to other forced induction devices and is ideal for a heavy vehicle with big tires. Turbo would have the cool factor for sure but would make more of its power in upper RPMs. Boost would come in right above idle on the positive displacement supercharger and probably about 2000RPM on the turbo before you see anything meaningful and 3000RPM before it's really putting out a lot of boost. The way you deal with that is having a higher stall torque converter (and possibly even more gearing) to let the motor get into boost quicker. A bit like revving it to 2K-3K RPM before you pop the clutch in a stick vehicle.
Do you mud any? Would not be good for an undermounted turbo.
