Insufficient PTV, now what?
1999 LS-1 60,000 miles on the stock short block
Texas Speed PRC Stage 2.5 5.3L CNC ported heads 2.02/1.575 valves, .017" mill on the deck, PRC .650" dual valve springs.
GM Multi Layer Steel Head Gaskets
Comp Cams LSr Cathedral Port 54-457-11 cam 223/231 @.050" .610"/.617" lift, 107 deg intake centerline.
LS-2 Timing Chain
I measured using stock lifters that were disassembled and shimmed to make them solid, installed checker springs and adjusted the pushrod checker for zero lash. Then I used a dial indicator on the valve retainer to check PTV.
When I measured intake centerline using the degree wheel , I got 105 degree intake centerline, but I feel that is within the +/- error I would expect using the tools I was. Exhaust PTV was fine, I saw a minimum of .150" between 5 and 10 degrees BTDC.
In helping to make the decision whether to fly cut or go more conservative with the cam, I will have an LS-6 Intake, Long Tube Headers and a T56. It is going in a 68 Camaro with 3.73 gears and it is a weekend toy. My gut feeling is to fly cut and keep the cam. The only thing bothering me is that it seems like these are pretty aggressive ramps and I am worried about valve train control. I probably can't return the cam now so I would take a hit on it, although I probably could resell it on here. What are your thoughts?
FYI, I ran my engine with .060" clearance checked with light springs. With the real springs, you gain even more due to deflection.
Going to .060 cometics would put you in the safe zone.
Retarding 3* could give you another .020 turning your .040 into .070 or there abouts. You lose a bit of compression but that cam sounds like it would have a lot of dynamic compression anyway.
I like your choice of cam, I would try to keep it but something does not add up. Have you CC'd the chambers ?
Not sure I would feel comfortable either, but just providing some additional thoughts.
The .060 Cometics would give .009" extra
As asked before, the chamber size is 61cc with the .017 mill
LS-2 Timing Chain
Also, the cam has 107 intake centerline, what is the LSA ?
I agree with dr_whigham, flycutting would let you keep everything you have and keep compression.
LSA on the cam is 112 deg.
As KCS states, that IVC is fairly early. I really don't want to get into adjustable timing sprockets since I bought brand new stock sprockets, but it may be worth it.
10 BTDC .140" PTVC
5 BTDC .100" PTVC
0 TDC .067" PTVC
5 ATDC .048" PTVC
10 ATDC .040" PTVC
15 ATDC .058" PTVC
20 ATDC .087" PTVC
Since you have a degree wheel I wonder what would happen if you installed one tooth retarded from dot to dot ?
IVO is 6.5 ° BTDC ( - indicates ATDC)
IVC is 36.5 ° ABDC
EVO is 54.5 ° BBDC
EVC is -3.5 ° ATDC ( - indicates BTDC)
Overlap is 3 °
As KCS said, this is a very early intake valve close. And, the is a very early exhaust valve open for this cam size and power level.
A much more common intake centerline for a cam this size in a LS engine with factory style long runner intake would be a 109 degree centerline. On a 109 degree centerline your valve events would look like this:
IVO is 2.5 ° BTDC ( - indicates ATDC)
IVC is 40.5 ° ABDC
EVO is 50.5 ° ATDC ( - indicates BTDC)
EVC is 0.5 ° BBDC
Overlap is 3 °
In my opinion this brings everything into line nicely. The valve events still look pretty good to me on a 108 degree intake centerline too:
IVO is 3.5 ° BTDC ( - indicates ATDC)
IVC is 39.5 ° ABDC
EVO is 51.5 ° ATDC ( - indicates BTDC)
EVC is -0.5 ° BBDC
Overlap is 3 °
In general I think you should find that every degree you retard the cam should get you about 6 thousands or .006". So, if you were to install it on 108 degrees your .040" + .018" would get you .058" and on a 109 degree ICL current .040 + .024" would get your .064"
If it were my car, I would run it on a 108 to 109 degree ICL if it gave me around .060" and call it good.
Another advantage of retarding 4 degrees is I would decrease the dynamic compression slightly. I am afraid that I might be prone to detonation with the current cam phasing.
