Tick vs Texas performance cams
Old Oct 7, 2014 | 09:33 AM
Sales@Tick's Avatar
Originally Posted by itsslow98
I would not put a big cam in a daily driver stalled auto car.
Agreed 100%.
If you already have a 233/239 camshaft then swapping to a camshaft with similar duration/lift/LSA will not net you large enough gains to make the swap worth it.
If you do not like the way that it drives you could go with a smaller camshaft that has less valve overlap, but in regards to making more power your best bet is going to be a good set of heads and/or intake manifold.
