Using the starter to prime rebuild
How long should it take to get pressure on the gauge? When i crank by hand, i can hear the oil sloshing around in the pan.
Looks like ill have to buy a home made priming tool. Battery's almost dead.
20 or 30 seconds "crank" time. No spark plugs:
Crank pressure test - YouTube
I just bought one of these drill powered pumps, so I'll try that if all else fails.
Plus, whenever I play with idle airfow too much and take it out where it refuses to start I can watch pressure build as it turns over.
In my Monte Carlo, in addition to the usual oil pressure gauge, I had a oil pressure switch (that would be used for a car with idiot lights) that would close a relay that powered my ignition. The ignition wouldn't work until oil pressure was built up. At the same time, if the oil pressure went away, the ignition would be killed saving the engine from damage.
When I re-build the Monte, I'll do the same but the relay will interrupt the fuel injectors instead of the ignition.
I had a 150,000 mile stock 4.8. Pulled the 4.8 longblock, and replaced it with a 5.7 longblock, with 243 heads and a custom cam/spring kit. Everything else like intake inj tb maf exhaust is all reused from the 4.8.
The tuners ive spoken to say it should fire right up and even run decent, but its not....
Guess ill check for spark (damn this is gonna hurt), and buy yet another one time use item, like a fuel pressure gauge and some fittings. Unless anyone knows an easier way to verify fuel pressure.
