what is this?
Old Oct 5, 2014 | 08:56 PM
BlkT/A01's Avatar
Default what is this?
So my car has been running rich and random misfiring but then after i idle it drives fine. Normally happens a little after start up. i found this was unplugged
where is it suppose to plug in at?
Old Oct 5, 2014 | 09:10 PM
BlkT/A01's Avatar
BlkT/A01's Avatar
back driver side
Old Oct 6, 2014 | 09:30 AM
BlkT/A01's Avatar
What's is it connected too? What's that a sensor too?
Old Oct 6, 2014 | 10:27 AM
kinglt-1's Avatar
That is a solenoid for the A.I.R injection system. When I deleted mine I capped off the connection for that black plastic tube. If not you will have a vacuum leak.
Old Oct 6, 2014 | 11:26 AM
01ssreda4's Avatar
^^^^^^that.
Old Oct 6, 2014 | 03:51 PM
BlkT/A01's Avatar
I have long tubes so my egr is gone. that is part of the egr system I assume right? So just cap it off?
Old Oct 6, 2014 | 03:58 PM
scotty2000ss's Avatar
Ahh, I saw that too after my egr delete. I will cap this off as well. The only problem I have is after the car warms up and I shut it off for a short period of time (say to get gas) when I start it back up it almost stalls. Only if the car is warmed up...
Old Oct 6, 2014 | 04:57 PM
kinglt-1's Avatar
No A.I.R Injection system that pumps fresh air into the manifolds to help pass emissions....totally separate from egr. 01-02 cars did not have egr anyway.
Old Oct 6, 2014 | 09:29 PM
BlkT/A01's Avatar
So shall i cap it or does it belong somewhere?
Old Oct 6, 2014 | 11:36 PM
kinglt-1's Avatar
Cap it
Old Oct 7, 2014 | 08:05 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Certainly not an internal engine thing like a piston or rod bearing. This is external engine stuff.
