cam suggestions for stock heads
Old Oct 6, 2014 | 03:02 PM
CATCH ME's Avatar
Default cam suggestions for stock heads
I am looking to get back into the fbody world after being out for a while and with all the new goodies out there I wanted to get some recommendations on a cam to run on stock heads. I'm looking to have a full bolt on M6 car that makes decent power but still can be driven daily. I was looking at the ms3 but didnt know if it could be run with stock heads. Anyone got any suggestions?
Old Oct 6, 2014 | 03:07 PM
HCI2000SS's Avatar
Yes you can run that cam with stock heads but you will want a steeper gear
Old Oct 6, 2014 | 05:24 PM
garygnu's Avatar
I have heard the Ed Curtis streetsweeper cam works good with a m6 .
Old Oct 6, 2014 | 06:07 PM
poltergeist 02's Avatar
Take a look at the SNS stage 2
http://www.tickperformance.com/tick-...1-ls6-engines/
Old Oct 6, 2014 | 07:29 PM
strracer09's Avatar
Sns stage 3 by tick preformance is the best m6 cam I've ran on stock heads
Old Oct 6, 2014 | 07:43 PM
American Psycho's Avatar
You can use the MS3 with stock heads no problem. If I was in the market again for a cam only set up; I would go with the Streetsweeper HT, or one of the newer Tick grinds.
Old Oct 7, 2014 | 07:29 AM
KCS's Avatar
KCS
Moderator
224/224 cam baby!
Old Oct 7, 2014 | 07:38 AM
vettenuts's Avatar
I have a friend running the Ed Curtis streetsweeper smaller version (I think it was 224/228 or something in that area) on a 112. He made excellent power with it and 241 heads.
Old Oct 7, 2014 | 07:49 AM
Tuskyz28's Avatar
234/246 cam by EPS. cam been 10s with stock heads in a M6 FBody.
Old Oct 7, 2014 | 08:04 AM
MMorgan9812's Avatar
That's moving, what other mods? I may look into this cam
Old Oct 7, 2014 | 08:26 AM
Tuskyz28's Avatar
https://ls1tech.com/forums/multimedia-exchange/1689523-cam-only-m6-10-86-a.html
Old Oct 9, 2014 | 08:35 AM
Sales@Tick's Avatar
Are the modifications in your signature the current modifications installed on the vehicle?
Any of the max effort Stage 3/4 type camshafts will require all the supporting modifications needed to perform optimally.
Old Oct 9, 2014 | 08:43 AM
JakeFusion's Avatar
Super Hulk Smash
A custom 227/234 (LSL/XE) 111+2 would be a good choice with stock compression while maintaining some drivability.
Old Oct 9, 2014 | 09:00 AM
thunderstruck507's Avatar
This is getting way too common...
Dial it back 2-3 notches from max effort cams or you're going to have a bad time.
Old Oct 9, 2014 | 07:35 PM
svede1212's Avatar
I had excellent results with a FTI Street Sweeper HT cam with stock heads, SLP LTs, 80mm TB and MAFless with an underdrive on my M6 LS1 GTO. I was just over 400 RWHP on a DynoJet. Tuning was the key (I did my own) and in the end I could lug it at 1,200 RPM in 6th gear with no surging.
Old Oct 10, 2014 | 10:19 AM
mjs1012's Avatar
I also have the streetsweeper ht with stock heads and it makes great power and is easy to drive. I could easliy daily drive it if I wanted to.
