Cam selection with mods
Old Oct 9, 2014 | 07:50 PM
jjnitrox's Avatar
Default Cam selection with mods
Hi Guys:
I would like your opinion and advice in a cam selection for my 04 automatic corvette. These are the upgrades.
vararam ramair CAI with power duct coupler
ls6 intake with ported & polished throttle body
243 heads(heads and intake are UNPORTED OEM)
25%underdrive pulley
slp equal length headers with CATLESS dual 2.5 x- pipes and borla catback
3000 stall speed converter
3.73 differential
Im looking for mid range and top end power the vette is for cruising and street and strip. I was looking @ tsp tv2(232-234 578-598),Lunati cam 20540714(227-233 584-584) and a comps cam (230-234 592-598) all at 114 LSa. Which one will you recommend or other cam in mind. I do not want problems with vacuum or brakes I do not mind a 1000rpm idle also I need to use air conditioning when cruising. Any suggestions or advice?
Old Oct 9, 2014 | 10:27 PM
99Bluz28's Avatar
With a 3k stall I'd go with the smallest of the three, but they all have fairly aggressive cam lobes. I recommend a cam with less aggressive lobes that has the potential to be more stable at high rpm levels while also being relatively easy on the rest of the valve train. Maybe a Comp Cams 54-428-11(228/230 112lsa+2, lift .571"/.573"), a Cam Motion LS2 Stage 3 (228/232 114lsa+4), or Cam Motion Titan IV (227/232 113lsa+4).
Old Oct 9, 2014 | 11:06 PM
kinglt-1's Avatar
^Solid advice!
Old Oct 9, 2014 | 11:12 PM
JakeFusion's Avatar
Super Hulk Smash
From all of those choices, Cam Motion Titan IV (227/232 113lsa+4) wins. Especially if you decide to port and mill the heads later. It'll like compression.
I'd also replace the stall with a 3600. It won't drive much different but will perform much better.
Old Oct 10, 2014 | 11:45 AM
jjnitrox's Avatar
Red face cam selection
Excellent advice.I will go with 227-233 from lunati.I forgot to mention that I will a cam kit with double springs and titanium retainers, I talk to the guys a TSP and they suggested the TV2(232-234) I think this cam will have a rougher idle than 227-233, I also got advice from a friend who suggested a comp cam 224-230. what do you think guys.
Old Oct 10, 2014 | 01:09 PM
TXZ28LS1's Avatar
Torquer 2 with 3600 or 4000 stall.
Old Oct 10, 2014 | 04:43 PM
redbird555's Avatar
i would go with cam motion like jake said. the cams are ground on a much better 8620 core...comp makes lunati and they have had issues here and there
Old Oct 10, 2014 | 04:45 PM
thunderstruck507's Avatar
What he said.
The small increase in price is much better than having to replace the cam and lifters
Old Oct 10, 2014 | 05:18 PM
99Bluz28's Avatar
I've never heard this.
Can you please pm me the info you have stating that Comp Cam grinds/cuts Lunati cams..?
Thanks!
