Turbo cam in NA application
Old Nov 9, 2014 | 08:26 AM
fastcrash30's Avatar
Default Turbo cam in NA application
I have an LEP turbo cam and had planned on a turbo setup for my LQ9 in my mustang as a DD.Well kinda need to get running now but NA for a sec, but I have this cam in already specs are: 236/234 .595 .595 117lsa how would this cam do in a NA application?
Old Nov 9, 2014 | 03:58 PM
Nobody?
Old Nov 9, 2014 | 05:05 PM
99Bluz28's Avatar
I would think the low-end power will be weak, but how weak will depend on the engines SCR, cams ICL, the rear gears, and TC stall speed if auto trans..
Old Nov 9, 2014 | 06:05 PM
3.55 gears and 5sp
Old Nov 9, 2014 | 06:09 PM
Tuskyz28's Avatar
I really don't like those specs due to the reverse split on the cam for a all motor setup.
Old Nov 9, 2014 | 08:27 PM
Yeah, the reverse split is what's making me weary as well.
Old Nov 9, 2014 | 08:50 PM
Tuskyz28's Avatar
If I was in your shoes I'll call someone like Martin at tick performance or Brian Tooley and ask them about that . I know for a fact Brian go give you a honest answer. On the other hand you just may be better off selling that cam and get one more suited for your application which is what I would do.
Old Nov 9, 2014 | 09:39 PM
SCott5's Avatar
What exactly are you asking?
Are you asking if it will be okay to drive till you turbo it? Make good power and keep it na?
Old Nov 9, 2014 | 11:36 PM
Yes, I've heard I can go either way with the cam specs. I'm no cam expert I've accumulated parts for a turbo build this cam being one of the parts on a trade. Just not sure if ill be finishing the whole turbo build this year but I already got this cam in and just wondered if it would make any power in a NA setup for the time being.
Old Nov 10, 2014 | 09:24 AM
ViaBellator's Avatar
Is it ideal? No.
Will it run and make decent power until you turbo? Yes.
That's the short answer. The long answer goes into overlap, cylinder pressures and other things the average person considers to be black magic when dealing with cams.
It's not going to make as much power as a cam designed for N/A, but it will beat a stock-ish cam all day.
