head gasket question
Old Nov 9, 2014 | 05:18 PM
emfh's Avatar
Default head gasket question
I am going to be doing a head swap on my lq4 and im trying to decide wich gasket to run. I will be installing a set of 243 heads milled .020. From my research that should put me around 10.5 to 1 so should i just run a stock replacement gasket or a .040 thick gasket? And if i ran the thinner gasket what would my compression be? This is a stock bottom end lq4. Thanks
Old Nov 9, 2014 | 07:40 PM
MuhThugga's Avatar
You'd probably be around 10.7:1 with the .040.
What are your goals with the motor?
Old Nov 9, 2014 | 08:15 PM
emfh's Avatar
Its in a 88 trans am with a fast 90 combo th350 with 3600 stall 390 gears 1 3/4 headers true duels. Its a street strip car looking to get as close to 10s on motor.
Old Nov 9, 2014 | 10:08 PM
.boB's Avatar
Never use a head gasket to adjust compression ratio. The head gasket sets quench, which will determine how efficiently your motor runs. Use the gasket that gives you a 0.035-0.040" quench. That will make more power, and help prevent detonation at higher compression levels.
Old Nov 9, 2014 | 11:19 PM
WSTEXAS's Avatar
agree with top post
