Rocker suggestions please
Old Nov 17, 2014 | 07:46 PM
66ss's Avatar
Default Rocker suggestions please
Had crane golds 3/8 stud mount. I liked them bc I'm a gen 1 sbc guy coming over to ls and they adjust like something I'm used to
Why do some like the pedestal mount?
I was leaning toward the comp cams pro magnum steel bodies
The lunati voodoo's look nice with the adjuster on the push rod cup like a jesel.
Thanks
Old Nov 17, 2014 | 07:50 PM
KCS's Avatar
KCS
Moderator
Jesel
Old Nov 17, 2014 | 10:11 PM
American Psycho's Avatar
If this is for a street setup; stick with the stock rockers. Time and time again the stock units with the trunnion upgrade have shown to be very sturdy, and also retaining their light weight.
Jesel are top notch if you want to spend over $1k.
Old Nov 18, 2014 | 02:44 AM
ls1 1990 VN's Avatar
What he said.
Old Nov 18, 2014 | 02:59 AM
Fullen's Avatar
I agree with the comp cams trunion upgrade. I've seen way more failures out of aftermarket rockers on street driving duty. It's easy to swap them out too.
Old Nov 18, 2014 | 03:14 AM
Robert Cantu's Avatar
Well I have a brand new set of Harland Sharp 1.7's roller rockers if your interested will let go for 220.00 shiped. Have pics if you want.
Old Nov 18, 2014 | 06:54 AM
66ss's Avatar
Yes it's a street set up. My cam needs a 1.8 rocker or the stocks would be an option. Sorry forgot that info. I like the stock set ups but have heard that the non roller tips wear the vavle tips and start making the edges sharp.
66ss's Avatar
Nobody runs the steel body comp ultra magnums?
Old Nov 18, 2014 | 12:32 PM
Fry_'s Avatar
Why does your cam need 1.8 ratio rockers? It would be cheaper to buy a new cam than it would be to buy a high end set of 1.8 ratio roller rockers. You may want to try forgetting everything you know about SBC's when working on a LS1, old school knowledge doesn't always transfer to newer stuff.
Old Nov 18, 2014 | 12:58 PM
03Sssnake's Avatar
Running the trunion upgrade, no problems...
When I did the trunion upgrade the Comp Magnum Rockers were not available for LS motors, but it also looks like they only sell 1.8 ratio rockers. I think they would viable stock rocker replacement if you could get a 1.7 ratio that could be bolted down to stock rocker stands, otherwise I would stick to the stock steel bodied rocker with trunion upgrade. Though I do like the roller tip on those magnums.
