Thread chaser for head bolt threads
Old Nov 22, 2014 | 07:27 PM
zTimbo's Avatar
Default Thread chaser for head bolt threads
Well I've recently discovered that GM used a 11mm x 2.0 thread in the block for the head bolts. I was wanting to chase the threads in the block before I install the heads. Does anyone have an alternative to the $60 thread chaser from ARP that I will only use this one time? I do not have any of the old head bolts to make into a thread chaser.
Old Nov 22, 2014 | 07:50 PM
Chevyman1968's Avatar
All you gotta do is take one of your old head bolts and cut a line down the treads and and that will act as a thread chaser. Then jet blow some compressed air in there to get he debris out.
Old Nov 22, 2014 | 08:47 PM
JRENIGAR's Avatar
Go to the hardware store and get one of each size head bolts to use as a thread chaser.
Old Nov 22, 2014 | 09:53 PM
93Z2871805's Avatar
Veteran: Air Force
^This. I cut 3 grooves in mine.
Old Nov 23, 2014 | 01:28 AM
zTimbo's Avatar
Refer to last sentence of first post.
Old Nov 23, 2014 | 01:51 AM
yonerhottlt1's Avatar
****, I'll send you an old head bolt that I already made into a thread chaser if you pay for shipping. Shoot me a PM if interested...
Old Nov 23, 2014 | 08:01 AM
01ssreda4's Avatar
An old head bolt works ok, but the ARP is better. Its a nice tool that works really well. I have one, and its been used numerous times.
Old Nov 23, 2014 | 10:15 AM
kinglt-1's Avatar
Lmao!
Old Nov 23, 2014 | 04:34 PM
93Z2871805's Avatar
Veteran: Air Force
Got me.
Get an M11 x 2.0 bolt and an M8 x 1.25 bolt and cut aforementioned grooves.
Old Dec 12, 2020 | 09:07 AM
TheLSBeast's Avatar
How dis you end up resolving this issue? Im in the same boat at the moment.
Old Dec 12, 2020 | 12:18 PM
LilJayV10's Avatar
You can either cut slots in a stock bolt or buy the ARP tool.
This isn't difficult people...
Old Dec 12, 2020 | 12:21 PM
Rich-L79's Avatar
Just get an inexpensive tap and die set and use the appropriate sized tap to chase the threads. Then you also have a tap and die set you can use again and again in the future.
Old Dec 12, 2020 | 11:23 PM
Sacrilege's Avatar
For all the people suggesting using a tap - NO. You NEVER want to run a tap down into a head bolt hole because it will remove too much material and make the thread weaker. If this is an alloy block, kiss that hole goodbye. You need to use a chaser or cut a slot into a factory bolt. These methods remove minimal material and mainly just form the thread back into place. An actual form tap would be ideal for this but M11 is a non-standard thread so I doubt you’ll find one for cheaper than ARP’s chaser.
Old Dec 13, 2020 | 11:38 PM
sjsingle1's Avatar
that thread size is hard to find....very hard to find....ARP must know this
Old Dec 13, 2020 | 11:46 PM
AwesomeAuto's Avatar
I just cut grooves in a stock head bolt and run it in/out with an impact lol. Never had a single issue.
Old Dec 14, 2020 | 10:47 AM
Rich-L79's Avatar
Unless the threads in the block are damaged the proper sized tap should not be removing any base material from the block.
Old Dec 14, 2020 | 02:06 PM
00pooterSS's Avatar
Good luck finding a tap/chaser long enough
That's part of why everyone recommends, and uses, an old head bolt or the ARP tool.
The old head bolt is free, the right length, wont harm the threads etc etc
That's the only answers, it's been explained many times, and people are still asking
Old Dec 14, 2020 | 02:30 PM
Sacrilege's Avatar
If the threads aren’t damaged, you wouldn’t need to be chasing them in the first place...
Old Dec 14, 2020 | 08:59 PM
CattleAc's Avatar
Well, there is a guy on flea bay that's selling a "homemade" looking one that's about $20 bucks less than the ARP one.
You can always resell the good one when your done with it. recoup some of your initial investment...
Old Dec 15, 2020 | 07:49 AM
WE TODD DID's Avatar
Actually you do to remove the old compound that is on the bolts that transferred to the block.
