single vs double roller
Old Dec 8, 2014 | 01:02 AM
ls1 1990 VN's Avatar
Originally Posted by jim1450
Just curious why no one ever mentions or gives the valve train what the car will be used for when deciding on a timing chain.
I'd think larger cams & high spring pressure would be harder on the chain. What about driving styles that are on & off the throttle a lot?
Cloyes hex a just with extreme C5R chain & LS2 damper fitted, if not drilled for damper use the Trick Flow bracket.
ATI Damper as well
Old Dec 8, 2014 | 11:56 PM
skinumback's Avatar
I have the cloyes ls2 hex adjust single roller with patriot duel springs .246@.50 .642 no problems for 4 years! No chain dampner either, I do have a ati balancer tho if that makes a differance
Old Dec 9, 2014 | 06:28 AM
poltergeist 02's Avatar
Originally Posted by ls1 1990 VN
NO!
I was using a 25% underdrive Powerbond
Ok, I see. Have you ever seen the thread about chains breaking from using 25% underdrive pulleys for road racing? In that thread it seemed as if it didn't matter what chain those guys were running but they all had one common factor that was linked to their chain breakage problem, and that was the 25% underdrive pulley.
Old Dec 9, 2014 | 10:50 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Have you guys checked out the "C7R" that Hinson started selling? It's supposedly stronger than the C5R and a seamless design... Just curious. It's probably the one I'm going with when I build the Vette.
Old Dec 10, 2014 | 12:30 AM
I may well have been in that thread as my dual Rollmaster broke while road racing with the 25% underdrive Powerbond
Always going to be something bigger stronger better, dearer etc
The C5R chain has not been broken road racing, did it need to be bettered, maybe, maybe not.
Old Dec 11, 2014 | 08:50 AM
dr_whigham's Avatar
The Scammer Hammer
Always going to be something bigger stronger better, dearer etc. The C5R chain has not been broken road racing, did it need to be bettered, maybe, maybe not.
I agree. Just another good option out there
