forged lq4 with worked 243's, ls6 intake, headers,exhaust,and a compression of 9.1 to 1. plan on spraying around a 250 shot, but want it to perform ok on motor, i know i cant have the best of both worlds but what would be the safest on n20 and decent on motor
That's cuz we were messin with ya. We didn't take it serious because you didn't take it serious, you didn't even bother to say what car this engine is in .
Originally Posted by busha61067
forged lq4 (what displacement) with worked 243's (flow #), ls6 intake, headers (what design & size),exhaust (true dual or ORY),and a compression of 9.1 to 1. plan on spraying around a 250 shot, but want it to perform ok on motor, i know i cant have the best of both worlds but what would be the safest on n20 and decent on motor
Auto or manual ? Stall speed ? What valve springs ? Timing set, oil pump, push rods ?
250 shot tells us you need more exhaust duration, LQ4 tells us you can handle more cam than a LS1, 9.1 to 1 tells us you need a bit tamer cam. Is it a daily driver, weekend cruiser or will it spend 20% or more of it's time on a 1/8 mile ? See, it's not a simple answer. The better you describe what you have and what you want out of it, the better someone can help.
Wonder if that EPS camshaft for LS3 engines 222/240 would be still responsive NA with the low static compression yet have that added exhaust duration to vent 750 foot pounds of nitrous fumes.
auto, 364ci, 70% street driving, 243's are getting a serious p/p job, valve springs and stall will vary on the cam, timing set will be ls2 type. I dint think the what car would matter I understand not putting the rest though, I was in a hurry so just put the bare essentials, im not sure what oil pump to run im thinking melling high pressure.
Seems like a heavy car (or truck) would like the 222 intake . I was thinking the Tick Blower cam but he doesn't need the wide LSA and needs more than 5* overlap. It sounds like someone built a motor for a Procharger and wants to run it on the bottle while they save up $ ?
