06 LQ9 Need Cam advice
I have some Kooks LTs 1 7/8, Kooks Y pipe, 3" electric cutout,corsa touring muffler, EFI Live tuned once I get cam in. And a SLP 160 Stat.
Did the Airaid filter and Tube to stock box.
The trans is a 4L70e, I plan to get a Circle D 278mm 3000 or a Yank TTS 3000.
Truck has 70K miles, so I will do both servos, and Transgo Kit with TC at install. Also, bought a Tru Cool 40K cooler to keep temps down.
The factory gears are 4.10s front/rear. Stock tire size(265/70/17), but plan on going to a 285/70/17 for less rpms on highway for mpg. (32.8in)
I tow a double axle trailer on occasion for work and a 27 FT CC boat on some weekends to ramp. Use the 4x4 when I go hunting to get to the camp, or at the track.
I have used the search button, but theirs some many options on cams, I'm trying to narrow it down with people's cam they use in the same application.
I'm thinking a:
1. 224/228 114 LSA
2. 220R-112 LSA
3. TR224 114 LSA
4. 228/228 .588/.588 on 112 LSA
5. 212/218
6. 216/220 561/.581 lift 113 LSA
7. 220/112
8. 232/236 .585 lift on a 112 LSA
9. 220/224 on a 112 LSA
10. 221/226 113+3
11. Your cam and advice?
Thanks for the help. I have no experience with cams, just FYI.
And
Add in some PAC 1218 springs and 7.4 Comp magnum Pushrods at cam install?
And new set of GM LS7 Roller Lifters Part# 12499225 too($98)?
or Just do the
COMP Cams GM LS1 LS3 LS7 Retro-Fit Rocker Arm Trunion Upgrade Kit #13702-KIT ($129)
BTW, I'd also get around a 180* t-stat, a 160 t-stat is too low!
https://sdparts.com/details/scoggin-...er/cc54-st1-11
Ill agree with said above cam that 99bluz mentioned and as said you need to look at overlap to help determine the "chop" or "lope" at idle.
Side note: id choose the yank truck truster over the budget circle D. Locally iv seen alot better 60' times come from the yank TT over the budget circle D converters
1) How is a WIDER tire going to affect rpm when the overall diameter (70/17) isn't going to change?
2) If you're doing the lifters, grab a set of LS2 lifter trays. Even if you already have them, I'd put new ones.
3) Any thoughts on running a .040 or .045 head gasket for an additional bump in compression?
4) I'd pass on the Comp trunion Kit and get the ones Brian Tooley sells. They're made of a more durable material... Better quality.
I do agree with the "Get Goeff at EPS to spec you a cam" statement. You will not be disappointed, and you won't beat the **** out the valve train using his proprietary EPS lobes.
285/70R17 = 32.7x11.2R17
= 1.1" Taller
2. Good idea, thanks.
3. How much more would it raise it will the .040/.045?
4. I'll take a look at them. Thanks
5. His reviews are pretty good across the web, and he was a pleasure to talk to on the phone, not telling me what I have to do or pushing a sale. Just advice and his past experiences.
With .045" head gaskets your SCR will go up right about .14, and with .040" head gaskets it'll go up about .26 .
As far as EPS cams I would look at the TT2 (218/226 113lsa) if you want a bigger cam, but I wouldn't go any bigger with towing and with a 3k stall TC..
http://store.cammotion.com/the-titan1
Grind# XA218/345-XA222/340-12+4
Duration at .050 - 218/222
Lift with 1.7 - .586/.578
Lobe separation 112
Intake center line 108
Usable RPM Range 1800-5800
The 2600 will retain stock towing capacity, the 3000 will be slightly less ideal.
They are both built on a 278mm platform so i wouldn't hesitate to tow with either.
Depending on the cam you choose to use, would determine the stall speed.
Lobe separation 112
Any way I only suggested the EPS TT2 as a better option than the larger EPS 222/226 113lsa cam.
Let ya all know how its goes once its in and post a video clip.
I've watched him do it about 100 times and every time I learn something new. It's pretty cool to hear it.
