Help!! Cylinder leakage test
Doing that squares the rings in the bore and seals them better.
I can't imagine all the rings failing suddenly.
I'd be tempted to carefully check the PCV system. Maybe even pull the intake manifold and see how much oil is in the ports.
Plugs all oil fouled?
What did you set the timing at? Were you using the ECU as it came out of the vette???
What were your leakage numbers on the cylinders you tested. Normally you pump in 100PSI and then see what the other gauge reads and it will be 95-100 for good and 90-95 for running ( but worn out to me ), lower than 90 indicates pretty worn out but still running.
You can listen to where the leak is coming from to see what is wrong. It will be intake ( i-valve ), exhaust ( e-valve ) or dipstick ( Rings ).
Mark@AlienChassisDYno.com
