fast 102 or cam install
Cam all the way. You'll enjoy it much more than a new intake!
Same time do valve springs, truunion rocker upgrade, pushrods.
Be wise, fit Cloyes hex a just gear set & extreme duty C5R or Hinson C7R timing chain with LS2 damper & trickflow bracket if blocks not drilled.
ATI super damper & H/Pressure not 'HV' ported oil pump while it can be gotten at.
H/Performance engines are not cheap!
