Shorten rocker bolts for ported heads
I noticed today when I pulled the intake off my 408 exactly how far the rocker bolts actually go into the intake runner. Id say a good 3/8 of a inch. Is there really any reason why I couldn't cut at least the amount that sticks into the port off.
What rockers are you running OP?
Why not just use the comp bolts? That's what I did with my AFR's and it worked out fine. Either way you'll be fine. But definitely shorten them.
Why not use the stock bolts and grind them off to fit the runners after being torqued down? This way they fit the runner shape exactly and dont leave a void for turbulent air to flow around. Just mark them for the runners they are ground to fit and reassemble them in that order.
I didn't want to use the comp bolts because that set of trunions I plan on using in my other car. And I actually thought about pulling the intake off and marking the bolts one at a time and contouring them to the port but I was afraid that having half the bolt grinded off might make it alot easier to cross thread and mess a bolt hole up.
Like suggested your gonna start them by hand anyways so they should start threading just fine.
Another thing I noticed today was that the comp bolts were not only shorter but threaded a lot higher up. If I did end up cutting almost half inch off the bolts I'll only have maybe half inch of threads holding the bolt in. Idk if since these are prc 247s and the port is just larger or what but these had probably half inch of bolt in the port. I may be better off getting more comp bolts and cutting them to fit.
