Oil pan choice??
Old Jan 2, 2015 | 12:13 AM
busha61067's Avatar
Default Oil pan choice??
I need to figure out if a stock fbody pan has enough capacity to safely supply and lq4 with .005 over pistons with 243 heads reving til around 6700 tops with a stock oil pump. all input is greatly appreciated/ if not will a ls2 gto pan fit in a stock fbody chassis. any suggestion on a pan? thanks ...also this car is auto with a 4l60e
Old Jan 2, 2015 | 06:45 AM
96capricemgr's Avatar
Why would you be considering the GTO pan in an f-body?
If you want to worry about it there are upgraded pan internals from some vendors to improve windage and cornering oil control in the f-body pan.
Old Jan 2, 2015 | 07:46 AM
01ssreda4's Avatar
I don't think any other stock pan fits an fbody chassis. If you want better oil control look into an Improved Racing pan baffle for the stock pan. It will control the oil movement during acceleration and cornering keeping your motor from starving. And generally most people run 1/2 to 1 quart over filled since the pan can hold it but gets pumped down quick at higher rpm.
Old Jan 2, 2015 | 08:02 AM
Paul Bell's Avatar
That's MISTER MODERATOR
I hate the tiny twisted passages the oil needs to take in the oil pan through the filter boss.
Get a Moroso pan that takes the lines & filter out of the pan and run a larger external filter.
http://moroso.com/eb/catalog/navigat...nuId=main.menu
Old Jan 2, 2015 | 08:09 AM
01ssreda4's Avatar
Isn't that pan and filter setup like $750+?
Old Jan 2, 2015 | 08:45 AM
And not that it matters for NA but compromises block strength by not being the structural member the stock pans are.
Looking at pics of the GTO pan it is nothing like the f-body, I would say no chance of it fitting.
Still curious what the OP thought the point of it would be.
Old Jan 2, 2015 | 01:28 PM
ImprovedRacing's Avatar
LS1Tech Sponsor
The only factory pan that will fit the stock chassis is the F-Body pan.
The only other option I'd recommend is the Holley front clearance swap pan, along with our baffle, which is similar to the F-Body pan. It does have slightly higher oil capacity too. http://www.improvedracing.com/baffle...pan-p-443.html
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
Old Jan 2, 2015 | 05:15 PM
busha61067's Avatar
gto ls2 pan had a higher oil capacity thats why i was wondering. and thanks for all the info!
Old Jan 2, 2015 | 05:48 PM
busha61067's Avatar
will either of those you guys listed fit without modification, also do i need one?
Old Jan 3, 2015 | 12:38 PM
LS1Tech Sponsor
The Holley front sump pan fits without modification in the F-body. Do you need one? Not really, just adding our baffle to the factory oil pan will achieve similar results.
You may want to also consider our crank scraper (EGM-300) as that also helps reduce oil starvation and customers have been gaining as much as 9 RWHP with it.
__________________
Old Jan 3, 2015 | 01:16 PM
busha61067's Avatar
does it reduce friction for those gains? and ill probably invest in that baffle after a little research
