MS4 113 LSA question
Old Jan 5, 2015 | 06:25 PM
Ls3fish's Avatar
Default MS4 113 LSA question
Hey guys, I just bought a ms4 cam from a friend and it's on a 113 lsa. It's going in a ls2/t56 4th gen. Will I be sacrificing any power with the 113 lsa vs the standard 111 lsa? THANKS
Old Jan 6, 2015 | 06:45 AM
redbird555's Avatar
it shouldnt make too much of a difference at all it will move the powerband up a couple hundred rpm though. what are your mods and what engine is this going in
EDIT: just saw ls2/t56 anyway that cam is pretty big even for an ls2, if you plan to use the car a l;ot on the street and want it to be fun you really need a good set of heads/compression and a set of 4.10's min imo
Old Jan 6, 2015 | 08:28 AM
HCI2000SS's Avatar
Depends on if there is any advance or not. Do you happen to know?
Old Jan 6, 2015 | 08:56 AM
Ls3fish's Avatar
I don't believe there is any advance. I'm using a ls6 intake and plan on using 4:10's or 4:30's. I have all the other normal supporting modifications. I'm usuing a btr .660 lift valve spring kit with titanium retainers. I would like to eventually get the 243's ported. And I don't really care about street manners
Old Jan 6, 2015 | 09:04 AM
HCI2000SS's Avatar
I don't think it will be a big difference between the 2 then...especially with the right gears and good compression
Old Jan 6, 2015 | 09:20 AM
VandykeT/A's Avatar
My LS1 prc215/ms4/FAST set up didn't peak until 6900 and that was on a 111lsa. The cubes will take a little away from the peak rpm so I'd expect around the same peak. 68-69. It was a little rev happy. Power started to come in around 5k but it wasn't bad. Even on the driveability. I think you'll be fine.
Old Jan 6, 2015 | 10:55 AM
Ls3fish's Avatar
Say I want to mill the heads .030, is there enough piston material there to flycut or would I be flycutting right through the piston?
Old Jan 6, 2015 | 03:22 PM
VandykeT/A's Avatar
You should be fine flycutting. We drilled through a stock LS1 piston just to see how thick they were and if I remember right it was roughly 1/2".
Old Jan 7, 2015 | 10:30 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
As mentioned, the 113 LSA will move the power band up slightly vs. the 111 LSA. You won't have any room for thinner head gaskets, head milling, or larger valves (unless it's an aftermarket casting head with laid over valve angles) without fly-cutting the pistons. If you're going to go through the hassle of cutting the pistons, I'd cut a minimum of .060". That way you have some extra room for down the road, should you need it. I cut as large as .120" intake reliefs in my 2002 SS Camaro 10 years ago running heads/cam and a 200 HP shot of N2O. I eventually bent a rod, but the pistons never had any issues.
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
