Anyone ever destroke a 6.0?
Yea, yea, I know, but, I dont want all those cubes, just some unshrouding of the valves with the 4" bore. I have not looked into what does what, but, maybe a good long stroke with extra shorty rods and tall pistons? Was thinking about the longer TDC dwell times + less cubes (for me) = a dog, lol?
Well for most LS guys who will only pay 200 for a complete valve train kit, it's too expensive. In reality though, short travel lifters, 3/8 PR, a good dual spring and hollow stem valves will get you there.
That was kind of my point. If you spend the money to do 8000rpms right, is the stroke length going to be material to achieving, 8000rpms for instance. A good quality crank and rods couled with a good valvetrain will probably have no durability change between a 3.62 and a3.25 stroke. So why not keep the cubes.
Why is the belief that the shorter stroke has to spin 8000 rpms to make power ?? A composite intake is well beyond its design by then.
Let's pick a target of 7200 or 120 revolutions per second
Every crankshaft revolution moves the piston all the way down and all the way up. Essentially traveling the stroke distance twice.
3.622 X 2 X 8 pistons X 120 revolutions per second = total linear inches of ring travel
Now devide by twelve to get feet per second
The stock stroke ends up being 579.52 ft/sec
The 4.8 crank at 3.27" travels 523.2 ft/sec at the same 7200 rpms
Roughly eleven percent reduction in ring travel/friction.
Now if the op was gonna build a 376 then the 36 extra cubes will matter.
However if he's replacing a 346 with a 340 cube engine, same rpm, I already
know which one will make more average torque. Perhaps a few less peak
ft./lbs. but more average.
