cam selection help
Old Jan 11, 2015 | 08:44 PM
gmoutdoorsman's Avatar
Default cam selection help
I cant 100% agree on which cam I wana go with. My build thus far: iron 347 inch (5.3 block,3.905"), 241 heads-blended bowls, smoothed/polished a bit. (270ish cfm intake),BTR .650 duel springs. Melling 10295 oil pump, LS2 timing set, LS7 lifters ,7.4" .080 PEP chromemoly pushrods. Stock rockers w/trunion upgrade to come. I've been told to go with a TSP Torquer V2. This will be an NA engine and probably a daily driver. Any suggestions?
Old Jan 11, 2015 | 08:54 PM
01ssreda4's Avatar
Rear gear, long tubes? Plan/goals for the car?
I really like the Titan4 from Cam Motion. Check it out.
http://store.cammotion.com/the-titan4
(All Titan Series cams are available in 3 Bolt and VVT.)
Grind# XA227/360-XA232/350-13+4
Duration at .050 - 227/232
Lift with 1.7 - .612/.595
Lobe separation 113
Intake center line 109
Usable RPM Range 2000-6400
Old Jan 11, 2015 | 09:52 PM
Lobe separation 113
3rd gen camaro, 3:42 gears (for now) Longtubes, 4L60e,3600 yank.400-425 rwhp goal to start. Plan on LS6 intake. And want it to be a daily driver or semi daily. With good drivability.
Old Jan 11, 2015 | 10:00 PM
I just really want a strong street car, that can handle daily driving, and a good beating at the track/street. Possibly hit 12's at the track.
Old Jan 11, 2015 | 10:14 PM
robdawg13's Avatar
"I've been told to go with a TSP Torquer V2"
Told by who and what about their advice are you having a problem with?
Old Jan 11, 2015 | 10:22 PM
01ssreda4's Avatar
I think the Titan3 or 4 would be an excellent choice for you. I'm running a similar grind from CM and have been very pleased with it.
Old Jan 11, 2015 | 11:41 PM
lsxdick's Avatar
I like those cam motion grinds. I would also check out speed inc and flow tech induction, something like a fti streetsweeper ht would also be a good choice.
Old Jan 12, 2015 | 09:41 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Our Torquer v.2 camshaft would be an excellent choice! Selection will certainly vary according to the overall setup. Our Torquer v.2 is a great choice for anyone wanting some nice performance gains without going too aggressive. Its specs are 232/234, .595"/.598", and your choice of LSA. We stock it on a 112 and 114 LSA, but we can grind it on whichever LSA you would like. It's also a great choice to help with valvetrain longevity because it doesn't use to aggressive of lobes to worry about valve spring life. Our Torquer v.2 is certainly a proven cam with consistent results!
Feel free to give us a call if we can help. We'll be glad to review all of your options with you!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 12, 2015 | 09:47 AM
01ssreda4's Avatar
Well which lobes is it ground on? "Not too aggressive" tells us nothing!
Old Jan 12, 2015 | 09:59 AM
redbird555's Avatar
The torquer 2 is ground on XER lobes so I would exactly call it completely beehive friendly. I would be more comfortable with duals on that cam. Cam motions grind or something from eps will run a beehive no problem and be easier on the springs than xer lobes
Old Jan 13, 2015 | 04:24 PM
No problem I totally trust his advice. I just like other peoples imput on things like this. Or of there is a similar
Old Jan 13, 2015 | 07:00 PM
01ssreda4's Avatar
That's funny, I don't go around bashing people's stuff (unless they truly deserve it) and I've heard there are a ton better cams out there then the torquer v2. Nothing wrong with it necessarily but from what I hear there are cams that are better drivers and still pull as good or better then the v2 up top. That comes from people I trust. I think there are better cams out there, even ones from TSP if that's your vendor of choice
Old Jan 13, 2015 | 10:03 PM
Im not partial to any vendor in particular. Just want the most bang for my buck. good wide powerband,good drivability. Great hp results
Old Jan 14, 2015 | 06:08 PM
gtotoocool1's Avatar
whichever grind you go with,make sure you take the time to set up the valvetrain properly and degree the cam.well worth the time and money..
Old Jan 14, 2015 | 10:33 PM
spicebird98's Avatar
the cam that ss recommended would would well with your setup. You could break 400rwhp but 425 is a lot to ask out of a stalled auto with a medium sized cam. Also being stock trans still you wanna decide on a mild rpm to shift at. i Wouldnt go over 6500 in my opinion. I tend to like a lower intake duration so u can mill the heads a bit more. Compression is your friend and a cheap upgrade. 229/234 111+1 with lobes of your choice would be my recommendation. 62 cc heads w/ .040 gasket
Old Jan 15, 2015 | 09:12 AM
thunderstruck507's Avatar
Don't get caught up in dyno numbers with an auto.
My car only made 389rwhp with better heads than yours and a 230/238 cam...but it ran hard in the 1/8th with some 7.4s@94-95mph in a 3700lb car.
I also like the Cam Motion grind mentioned above. I greatly prefer his cams due to being on better cores...worth every penny of the extra price upfront to know you won't have to do it again.
Texas Speed can probably get cams on those as well if you go custom order.
Old Jan 15, 2015 | 09:18 AM
Tuskyz28's Avatar
That's hauling ***!!
Old Jan 15, 2015 | 09:30 AM
Never ran hard out back though for some reason...best was 11.67@115mph. Best trap was 116mph. Then it just started getting slower and slower, finally took it apart and now I'm replacing it with an ls2.
Old Jan 15, 2015 | 10:03 AM
01ssreda4's Avatar
Something was wrong for only 10/12 mph on the back end seems like....
Old Jan 15, 2015 | 01:41 PM
Plan on getting a 60E mildly built. Already got stock mls head gaskets I think .051 or whatever stock LS1 is. And the 241's im not getting milled for now. 66 cc. 5.3 block is decked a tiny bit, with flat tops
