speedmaster gaskets?
http://store.speedmaster79.com/p-425...bore-3945.aspx
anyone hear anything about them.. or has anyone used them? opinions about using them
It takes .007" milling to remove 1cc from an LS1 head. 241 milled .015 yields around 10.3 to 1 compression ratio.
With Graphite/composition gaskets, for 2003 MLS gaskets subtract .1 to .2 from the ratio. Also, milling can hurt head flow.
241 has 66.67cc chambers for 10.1 to 1 Compression. Intake = 200cc Exhaust = 70cc
706 has 61.15cc chambers for 11.1 to 1 compression. Intake = 200cc Exhaust = 70cc
243 has 64.45cc chambers for 10.5 to 1 compression. Intake = 210cc Exhaust = 75cc
98Zeric, do you have a link to just the head gaskets ?
edit: http://www.jegs.com/i/Speedmaster/74....1013/10002/-1 I think I found it.
http://store.speedmaster79.com/p-383...3945-0040.aspx
they also have a few others at different bore size
Thank you sir for posting your find !
the copper seal spray is a great idea! I happen to have a can in the garage haha
"Where it matters"? So getting quality head gaskets is not "where it matters"?
As someone who has dealt with Speedmaster79/Procomp Electronics in the past. All their products are JUNK and should be avoided no matter how attractive the price.
You're quite welcome.
If the head gasket really is .040 thick with holes in the right place and it seals enough to keep the chocolate out of the peanut butter. I DO plan on buying from your store some other parts but feel Cometics are too expensive for what they do.
While your in here coSPEED, do you sell a gasket kit, crank bolt, front seal as a package deal for a cam swap ?
I would never trust anything from Speedmaster79. Nothing like a blown head gasket to deal with.
Oh their cylinder heads. LS cylinder heads you have to mill because they come uneven.
Total junk. You should pop open one of their "msd" boxes. The electronics are total junk.
There is more, just buy their stuff and find out the hard way.
