Ordering Cam Kit right now, which springs?
The Lunati and BTR dual valve springs are your best bet.
http://www.coloradospeed.com/1998200...d=521&sort=20a
http://www.coloradospeed.com/lunati-...0-p-13960.html
Ignore the blind brand fans that don't address what cam and what springs you are considering, you are choosing between two reputable companies, worry more about specs and understand there is one primary wire provider and just a very few spring winders that make a LOT of different specs for a LOT of different brands.
A lot of the springs people debate about are the same damned spring in two different boxes.
Both are quality spring kits, I think this decision should be more about which company you trust to stand behind there product and give you better customer support and services.
Went with BTR and Ti retainers, yes it was a kit with a choice of two. Ordered the Tick SNS stage 3. 235/242 111+2 I think. I need to memorize my specs, I've been looking at so many cams and numbers lately it's a blur.
Martin @ tick recommend Tooley springs with most of his cams....
