Cam Motion LLR Low Lash Roller Street Cam Install With Dyno & Track Results
#141
I actually was talking to Martin at Tick Performance when he recommended a solid roller from Kip. So I'm going with his recommendation with a Cam Motion roller lol. I have a new 428 coming. New LS2 block with 4.125 stroke should be a lot less nitrous to run 9's now.
#147
Btr 660 ti retainers
Hey guys I'm building s 443ci 13.2 comp e85 ls2 with ls3 heads super victor and a cam motion lls. Just wondering if the btr titanium retainers are ok or should I go back to tool steal?
#149
#151
Springs are PAC 1208x. The build is a hj Holden kingswood sedan approx 1380kg 9in diff with 31 spline axles alloy carrier and 3.9 gears, th400 box with trans brake and 5500 nitrous converter eng in a datron sleeved ls2 block with 4.135 bore and 4.100 crank (440ci) k1 crank lunati rods, cp Pistons, hand ported ls3 heads, Jessel shaft mount rockets, super victor manifold with a 2in spacer and will be a nitrous plate system spraying around a 300 shot, the cam motion lls cam 13.2 comp e85 fuel 275 60 15 pro radial tyre
