oil consumption
Both the shops that were involved with the rebuild, one did machine work and the other everything else, say that is normal for an ls1. Really? A rebuild causes the loss of an extra 1.25 quarts of oil every 3000? Anyone care to a crack at this one? Any suggestions on what may have caused the extra usage? I'm all ears or should I say eyes. I personally use over 2qts every 5k easily in EVERY LS1 car I've owned 5<last one for me> after this one ***** the bed I'm buying a Chrysler product. My Jeep has over 250k and still runs like new. Friend of mine has a Charger that he beats the living **** out of without any of the bs issues GM cars always develop.
Lifter noise-failure Oil-usage Rear failures Next time it rains open the hood and watch the water run all over the engine from the windshield cowling that has about 40 freakin holes in it! I could go on but Christ can't gm build anything that holds up? HELL NO they don't give a rats azz! If they cared about their customers they would have never dropped the fbodies in the 1st place.
My 01 WS6 with 36k easy miles had a bad axle, oil usage problems 1qt every 1-1.5k, bad torsen carrier, broken tilt steering, bad power steering pump, leaking water pump gaskets, bad lifters, broken driver power seat, and now at 88k its using oil like hooker in a hotel room. AND the tilt steering is broken again AND the torsen carrier is one legging again. ****** JUNK!
How do the spark plugs look, and do they all look the same..?
I'd also check the crank case pressure. There should be some vacuum pull on the palm of your hand when placed/removed from over the oil fill cap hole while the engine is idling. If it positive pressure trying to push you hand away then it's clearly a blow-by problem and I'd do a leak down check on all cylinders to see if you can narrow it down to jus a few cylinders.
are you sure it was bored as the max material removal is only .005" or ten thousandths total bore increase
reason I ask this is that most likely a shop only power honed it out to size If they didn't start with coarse stones, then medium, then fine, with perhaps a final flapper wheel stroke or two, it will have a ring seal issue. either they aren't seating or the moly has been wiped off the primary ring.
Bore finish simply can not be overlooked or shortcut...its WAY more than just getting it to a size hole that the piston fits into.
ANY top notch engine builder will tell you that there can be as much as 20-30 horsepower between a "that'll do" job and "the right way"...not to mention the oil consumption, burning plugs, smoking, high emissions crap.
Also, assuming you've already looked for heavy leaks, but it's pretty easy to break a brand new oil pressure unit on the back of the intake during installation. Ask how I know...
Which LS6 PCV system do you have ???
The original "old" style IIRC still needs a PCV valve in line in the TB hose
The "new" style uses a fixed orifice (restriction) which is located on the inside of the valley cover.
