Oil pump replacement questions?
In the writeup, it says you should loosen the bolts on the oil pan in order to access the bolt/o-ring for the pickup tube: which leaves me with a few questions:
I know the oil pan gasket is riveted in... But will lowering the oil pan and reusing the stock gasket open up the possibility for leaks?
I know most people say to use some RTV when mating the oil pan and timing cover, but what about the rear seal, behind the transmission?
And how easy is it to crimp the O-ring? Any tips to prevent it from crimping?
My pan gasket did not seal at the back. The motor had been rebuilt, and the previous owner used rtv in the back corner. RTV wont seal up a 2nd time once its dry like that. I have a very good sized oil leak from the back now. Will be dropping the pan this weekend to put a new gasket in. Oh joy...
How are others handling this? Is it a non-issue on an unmolested motor?
Loosen motor mounts. Place floor jack on bell housing and lift motor up slightly to give room between pan and K member.
Take the pan down as far as possible. Now there's 2 rivets from GM that hold that gasket on, towards the middle of the pan on the outsides. Take a sharp"ish" flat tip screw driver and knock the head off on the ground side. I'd advise a piece of duct tape or a rag between the inside pan lip and block just in case it pops "up" and that other little piece of rivet pops out. You don't want that in the oil pan.
Then, actually REMOVE the pick up tube and lay it flat in the pan. It's a single nut on a stud that holds the pick up tube. Nothing hard at all. That's the only way you can snake the old gasket out and the new one in.
Once it's in place, put a few bolts through pan and gasket to keep it aligned and in place. Put pickup tube back in oil pump, and THEN reattach to the stud that holds it in place on the windage tray.
RTV Ultra Black the front and rear lips. Secure bolts to pan/block. Re secure motor mounts.
Crack a beer.
From dr_whigham:
Take the pan down as far as possible. Now there's 2 rivets from GM that hold that gasket on. Take a sharp"ish" flat tip screw driver and knock the head off on the ground side. I'd advise a piece of duct tape or a rag between the inside pan lip and block just in case it pops "up" and that other little piece of rivet pops out. You don't want that in the oil pan.
Crack a beer.
Now, this is going to be interesting. It wasn't bad getting the pick up tube in with the timing cover off where i could see everything. This will be a bit more challenging. I am thinking leave the pick up tube loosely bolted to the windage tray to allow me more flexibility installing it into the oil pump.
Edit: i just re-read the original directions, and it was almost exactly what i was thinking.
If you can do that without pulling the timing cover off, maybe I'll roll the dice with the stock gasket?
